Will 954 harness fit 929 speedo?? HELP!! - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 07-28-2008, 11:04 AM Thread Starter
I have a 929 harness and ECU that is running a full 954 swap engine and TB (SUPRISE!!). I am considering swapping out the 929 harness and ECU and going with the 954 that I think should have been used. If I go with the 954 harness will I need a 954 speedo or will the harness connect to the already installed 929?? Sorry for the confusing talk. Please let me know!!!
biggup21 is offline
post #2 of 5 Old 07-28-2008, 12:29 PM
Re: Will 954 harness fit 929 speedo?? HELP!!
I don't know if the connector is different but according to the wiring diagrams the wires are.
Doesn't look like a big job to re-wire the pins though.
post #3 of 5 Old 07-29-2008, 6:06 PM
The plug is different. The 954 plug has an extra wire for the turn signal relay, too. I wasn't the one who did the swap on mine, though, so I can't give you any help on this.
Nick
Hasdrubal is offline
post #4 of 5 Old 08-01-2008, 11:41 AM
This just helped explain why you are having so many problems. I believe I said it seemed to be an electrical problem.
rjarrowman is offline
post #5 of 5 Old 08-01-2008, 4:04 PM Thread Starter
When did you say that I had an electrical problem???
Rather then swapping out the wiring harness and ECU, should I just use a pc3 and get a custom map made for the bike?? I have spoke to a couple board members that have ran this setup with all 929 electrical and just had the 954 motor. Thinking about doing this approach rather then swap electrical (pay for that) then hopefully sell my 929 electrical, and then get it tuned if need be because I will still have the low rpm hesitation.
Insight welcome
biggup21 is offline
will a 929 radiator fit a 954? Oldirtybob Honda FireBlade 1 07-10-2008 5:43 AM
Rectifiers, Will a 954 Fit a 929??? Fastnovice Honda FireBlade 5 11-26-2007 5:07 PM
will a 954rr speedo ( gauge) fit a 929rr?? emazens Honda FireBlade 2 11-16-2007 12:26 PM
Will 954 CPU/harness work for a 929 block??? Sprusgoose General Discussion 3 02-28-2005 5:49 AM
will 954 can fit 929? 2bitsamile Honda FireBlade 2 02-23-2004 2:45 PM
