sputter/stumble under 2500 rpm - Honda Motorcycles - FireBlades.org
post #1 of 12 Old 07-31-2008, 7:05 PM Thread Starter
OK at the risk of getting eaten alive I need to ask. I swear I have searched all over this website but the only hits I got were related to 929/954 with fuel injection...so... Some help or a link would be greatly appreciated. I have a 96 Blade all stock except Yoshi bolt on, and it sputters under throttle when starting from stop until it hits about 2500 then it takes off. It seems to get worse (more throttle and time to reach 2500) after riding for awhile or on a hot day. I have since replaced the plugs (appeared to be running a little rich) with iridium and replaced air filter. Where do I look next? Please help. Thanks in advance.
tacdawi is offline
post #2 of 12 Old 08-02-2008, 8:46 AM Thread Starter
Re: sputter/stumble under 2500 rpm
No one? Don't make me go to a mechanic with a wad of cash and a question mark.
tacdawi is offline
post #3 of 12 Old 08-02-2008, 12:37 PM
Quoted: 6 Post(s)
Reputation Power: 26
Hard to diagnose something based simply on a description, but my initial reaction is that maybe you should simply keep the revs up. I can't image riding at less that 5000 rpm, except in downtown traffic when still in first gear.
Did the bike ever spend a long time without running? like over a winter with normal fuel still in it? Maybe carbs and jets need a thorough cleaning. And how long has it been since the carbs were synchronised?
Was it rejetted for the Yoshi bolt-on?
ghbzorro is offline
post #4 of 12 Old 08-03-2008, 12:13 AM Thread Starter
I hear you on keeping the revs up but it is in traffic where it causes grief. Such as merging, or yields, at low speed in first then when I get on it to accelerate it bogs down and sputters, other that that no issues. Since I've owned it the longest it went without running would be a week. It was kept in a heated garage and started up every other day during the winter. Cleaning maybe, I didn't take them apart completely as I ran out of time and wanted to ride but the intake area was spotless. Synch sounds like a good culprit and as for the re-jetting I believe it was. I intend on getting a new jet kit and full exhaust over the winter so if thats the problem that should solve it. Thanks very much for the help my local guru is unavailable for a little while.
tacdawi is offline
post #5 of 12 Old 08-03-2008, 12:55 AM
Quoted: 198 Post(s)
Reputation Power: 25
That is very bad for an engine. Winterize it and let it sit.
As for your issue. The low speed might need to be adjusted. Also, what is the idle set at?
lanbrown is offline
post #6 of 12 Old 08-03-2008, 1:35 AM
Reputation Power: 12
Syncronise the carbs and see if it gets better. It sounds like a rich condition off idle as it gets worse with a warm engine and higher outside temps. Also, check to see that your pilot screws are set correctly. I never winterize my bike. Instead, I make sure to ride at least once a month during the winter and burn off a full tank of fuel. Just an option.
exit90a is offline
post #7 of 12 Old 08-03-2008, 2:37 AM
Quoted: 198 Post(s)
He is in Canada, which winter lasts 9 months.
lanbrown is offline
post #8 of 12 Old 08-03-2008, 3:37 AM
9 months!? I can barely stand a 4 month Ky winter!
exit90a is offline
post #9 of 12 Old 08-03-2008, 3:40 AM
Quoted: 198 Post(s)
Ok, it isn't 9-months, only 8. lol It depends on where he is, but it would probably be colder there. So riding may not be an option.
lanbrown is offline
post #10 of 12 Old 08-03-2008, 8:55 AM Thread Starter
I wish you were wrong but....where I am the winter is 8 months long usually with snow that long too! However when I lived in, BC I rode year round with the exception of a week or two here and there. (just to alleviate any rumour of an arctic Canada ) (So I never winterized, I guess thats something I will learn and do.
tacdawi is offline
post #11 of 12 Old 08-03-2008, 8:58 AM Thread Starter
Thanks. I appreciate all the input. I'm no noob, but an intermediate at doing my own bike work.
tacdawi is offline
post #12 of 12 Old 08-03-2008, 9:00 AM Thread Starter
The idle is set for 1200, I just checked my manual and that appears correct.
tacdawi is offline
RC51 One cylinder not firing under 5.5k rpm Ideas? rebelfish Honda RC51 3 07-23-2008 4:47 PM
Stumble below 3000 MateFeedKill Honda FireBlade 36 07-15-2008 7:09 AM
Small throttle opening stumble KDA Honda RC51 1 08-30-2007 5:39 PM
Sputter Custom900 Honda FireBlade 2 05-04-2006 11:30 AM
Major stumble (mid range) - please help chadcoon7 Honda FireBlade 9 09-30-2005 7:29 PM
