Carb problem - Honda Motorcycles - FireBlades.org
post #1 of 11 Old 08-21-2008, 8:43 AM Thread Starter
Quoted: 20 Post(s)
Reputation Power: 15
Carb problem
Ive just installed a dynojet kit in my1995 blade. it says to turn the mixture screw down but can someone tell me where the mixture screw is. thanks jon
jon 8214 is offline
post #2 of 11 Old 08-21-2008, 9:53 AM
Re: Carb problem
I have a set of early carbs somewhere but can't seem to find them just now.
I think the screws are under the front where they go into the manifolds.
post #3 of 11 Old 08-21-2008, 1:11 PM Thread Starter
Quoted: 20 Post(s)
Re: Carb problem
just looked at the service manual is the pilot screw the same as the mixture screw. cheers jon
jon 8214 is offline
post #4 of 11 Old 08-21-2008, 8:56 PM
Re: Carb problem
Yep. It adjusts the mixture of fuel and air.
post #5 of 11 Old 08-21-2008, 9:06 PM
Re: Carb problem
As Bladeracer mentioned, it is under the carbs in front of the bowls. It takes a D shaped tool to adjust them. Some jetkits come with it, hopefully yours did. What exhaust are you running? Personally, I would start off with some 120 mains, needle in 3rd position (from the top) and crank those mixture screws out about 3 to 3 1/2 turns.
cbr900racer77 is offline
post #6 of 11 Old 08-22-2008, 3:33 AM Thread Starter
Quoted: 20 Post(s)
Re: Carb problem
i didnt need a d spanner it was a phillips head screw i used a flat head to turn. i have standard downpipes with a viper race can with removable baffles. it said to use 122 jets and i put the needles on the 3rd position and set the mixture screws to 2 1/2 turns out like it said in the dynojet booklet. cheers jon
jon 8214 is offline
post #7 of 11 Old 08-22-2008, 6:05 AM Thread Starter
Quoted: 20 Post(s)
Re: Carb problem
forgot to say i also have a k&n
jon 8214 is offline
post #8 of 11 Old 08-22-2008, 5:05 PM Thread Starter
Quoted: 20 Post(s)
Re: Carb problem
give me your ideas. cheers jon
jon 8214 is offline
post #9 of 11 Old 08-23-2008, 12:25 AM
Re: Carb problem
I installed the same kit on my bike. I read somewhere that the mixture screw is set depending on what altitude you are going to ride at most. 2 1/2 turns was not enough for me. Through research I read while the bike is running, blip the throttle quite aggresively. If it hesitates or bogs, you need to turn it out more, then repeat. I went 4 turns out and it runs good now.
Of course you may need to play with the needles. If your bike is stumbling off the line or when you roll of the throttle, you need to drop the needles (go up a notch). It's a pain is the ass cause it's trial and error. Good luck
Skater! is offline
post #10 of 11 Old 08-23-2008, 3:06 AM Thread Starter
Quoted: 20 Post(s)
Re: Carb problem
thanks skater i am in germany and im told that the altitude isnt above the normal so hopefully it will work i havent tried it yet as im waiting to fit a new engine after my chain snapped and cracked the casing, i will let you know how it goes and i may need to pull on your knowledge again. thanks jon
jon 8214 is offline
post #11 of 11 Old 08-25-2008, 7:18 PM
Re: Carb problem
Do ALOT of plug checks. Got a friend with a faster bike? That is the best dyno on the planet. Do some 4k rpm rollons in 4th or 5th gear and note the results. You'd be surprised how big a difference one notch on that needle or one size different main jet will make.
Carb? Rod_dude Honda CBR400RR 8 08-27-2008 5:26 AM
900 RR carb/choke problem? simple3377 Honda FireBlade 5 06-09-2008 9:32 PM
900rr carb sync problem kiai Honda FireBlade 12 05-31-2008 12:42 PM
Carb Sync booracer General Discussion 4 09-20-2007 6:36 PM
Carb issue Fastrr Honda FireBlade 0 05-20-2007 9:09 PM
