954 Wheels??? - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 09-13-2008, 12:41 AM Thread Starter
954 Wheels???
Is there any additional work to put RC51 wheels on a 954 or will they bolt right up? If there is additional work, how much? I really like the 5 spoke design better than the 3.
Thanks
Seanbaker68 is offline
post #2 of 6 Old 09-13-2008, 2:01 AM
Re: 954 Wheels???
Discs are the same bolt pattern so I can't see there'd be much work in it.
post #3 of 6 Old 09-13-2008, 5:14 AM
Re: 954 Wheels???
Front wheel bearings & dust seals will have to be changed for 954 items so the 954 axle & spacers will work but thats it I think.
Rear wheel is idential I think
King Kenny is offline
post #4 of 6 Old 09-13-2008, 5:37 AM
Re: 954 Wheels???
Good point.
The front RC51 axle is only 22mm so you'd need to swap 25x47 bearings in and replace the centre spacer with a 25mm one - probably from your 954 wheel if you're lucky and they're the same length. Otherwise take the 51 spacer to a machinist and have him make you one exactly the same length but with a 25.25mm bore out of aluminium.
Axle spacers I would expect to have to make your own anytime you fit a different wheel.
I recommend replacing bearings anytime you swap a wheel anyway simply because they're so cheap.
post #5 of 6 Old 09-14-2008, 11:28 PM Thread Starter
Re: 954 Wheels???
OK I will have to look into that then. Thanks a lot for the info
post #6 of 6 Old 10-03-2008, 12:13 PM
SAK
Re: 954 Wheels???
any update on it? i wanna do that with my bike
SAK is offline
Carrozerria wheels 954???? ezekiel808 Honda FireBlade 0 11-26-2007 10:43 PM
929/954 wheels wytwlf Tools / Garage / Paddock 5 10-10-2007 7:43 PM
RC51 wheels on a 954 ??? Modded954 Honda FireBlade 7 10-09-2006 4:39 PM
929 Wheels fit 954? quincey Honda FireBlade 2 12-15-2005 8:35 AM
