03 954 pump not going on - Honda Motorcycles - FireBlades.org
post #1 of 17 Old 09-20-2008, 3:16 AM Thread Starter
ok swo i just picked up a 03 954 needs some tlc well this kid hacked the wiring on this bike so i said hell il get a harness sooo i put the main harness in and poof pump isnt goin on and fi light is lite after u try to start it i changed all the relays to the ones it came with/////the bike was running wen i got it the wires were hacked and the tack wired were no more please advise
954kid911 is offline
post #2 of 17 Old 09-21-2008, 1:27 AM
Reputation Power: 12
Re: 03 954 pump not going on
These should help. Grab a test light and dig in.
954wiringpg1.jpg‎   954wiringpg2.jpg‎
maherj is offline
post #3 of 17 Old 09-21-2008, 4:05 AM Thread Starter
hey thanks found one prob now have another ques where is the angle sensor what does it look like where is it?
post #4 of 17 Old 09-21-2008, 4:06 AM Thread Starter
post #5 of 17 Old 09-21-2008, 5:39 AM
On the 954 I think it's on the back of the headlight.
post #6 of 17 Old 09-22-2008, 11:29 PM Thread Starter
ok now i got it all figured out i got the new harness for the tac and i jumped the angle sensor nowww i have no spark the bike ran perfect with no probs b4 i did the harneses i had to unplug the ecu now i have no spark from the ecu i checked everythin u think it maybe the ecu i have injectors pumping away but no spark im stumped any info ?
post #7 of 17 Old 09-22-2008, 11:48 PM
Why did you jump the bank angle sensor?
If you re-connect it do you get spark?
post #8 of 17 Old 09-23-2008, 9:20 AM Thread Starter
im thinking the guy who had the bike before me used it as a streetfighter the front harness was mutilated soo i did all the wires the bankangle sensor was on it so i twisted the oter side wires together i jumper it rite ?
post #9 of 17 Old 09-23-2008, 9:26 AM Thread Starter
i have no poer coming out of the computer to the injectors at all the injectors work ok all sensors are connected ok kickstand sensor ok i tryed everything
post #10 of 17 Old 09-23-2008, 9:30 AM
I haven't opened up the bank angle sensor to see how it works but as far as I know it's a simple sliding switch which is normally open. It closes when the bike falls over.
I don't think jumping it is as simple as twisting the wires together.
Reconnect it and see if it works...
post #11 of 17 Old 09-23-2008, 7:44 PM Thread Starter
i never had one when i got the bike it was off the guy really f***ed up the wiring on the bike i believe he stunted it so he didnt want the bank sensor i saw on forums to tie together the outer 2 wires to jump it how can i check to see if its the ecm i might have blown it when putting wires back together and i pluged the mapsensor plug to the tps and the tps to the map
post #12 of 17 Old 09-24-2008, 1:22 AM
Hmmm...maybe jump it the same way it was jumped on the old harness then?
The only practical way to check the ECU is to replace it with a known good one and see if the problem goes away.
post #13 of 17 Old 09-26-2008, 9:43 AM Thread Starter
ok so i ordered a bankangle sensor and a new ecm off ebay hopefully it will work a new ecm is $850 so used will be just fine lmao
post #14 of 17 Old 09-27-2008, 3:52 AM Thread Starter
put the bankangle sensor nothing waiting for the ecm hope to god thats the problem
post #15 of 17 Old 09-27-2008, 2:39 PM
had the same problem man you should try the this i was in the same boat you are Ok here is what i am dealing with.
Bike will turn on but no pump.
Here is the problem. DIODE under the ignition switch.
When this goes bad or breaks you can replace it with a new one.
What it does!
I am not sure how it works but it supplies the ICM with around 9v of power. IT IS NOT A RESISTOR.
Ok here is the backyard way to test this. IT WORKS I JUST DID IT!
(For a quick fix)
Take a 9v battery and ground the neg side to the frame. Now take the connect the pink wireunder the ignition to the positive side.
Turn the bike on and the pump will kick on if the diode is bad
try this man a new diode is like 5 dollars
kagmyster00 is offline
What's the going rate on a few 954 parts prorider17 Honda FireBlade 2 09-16-2008 6:03 AM
fuel pump wont wind on start up 954 cbr954ns General Discussion 3 03-29-2008 3:56 PM
Fuel pump not coming on RoooStEr Honda RC51 5 05-15-2007 5:30 PM
Fuel pump problem 03 954 ReSpEcT Honda FireBlade 1 03-17-2007 11:27 PM
Bike's Fuel pump will not kick on xxshawnxx Honda FireBlade 6 05-31-2004 1:34 AM
