Oil capacity on an 07 Blade - Honda Motorcycles - FireBlades.org
post #1 of 3 Old 09-25-2008, 8:15 PM Thread Starter
Reputation Power: 12
The manual for the 07 Blade indicates 3100cc of oil when the filter is replaced.
I am using a K&N oil filter and when I pour in 3100cc of oil, the level is barely above the minimum line in the site glass. 3200cc puts the level in the center of the site glass. Does the K&N filter hold more oil compared to the Honda filter to cause this?
segiano is offline
post #2 of 3 Old 09-25-2008, 9:34 PM
Re: Oil capacity on an 07 Blade
The figures in the manual are nominal and dependant on how much oil you managed to get out when you drained it.
What matters is the level rather than the amount.
post #3 of 3 Old 09-26-2008, 2:35 AM
Mor
The manual for 08 Blade indicates approximately 3.0l, but last oil change (with filter) I needed to pour 3,2l of oil to max level on the dipstick. So I think, that your situation is normal and you just should fill the oil to the correct level.
Mor is offline
08 CBR1000 Mirrors on an 07 nighthawk54 General Discussion 0 09-22-2008 12:46 AM
Timing on an 07 1000rr stratsRR Honda FireBlade 0 07-31-2008 1:24 PM
Michelin Pilot Road CT2 on an 07 Blade guvna General Discussion 13 04-30-2008 10:03 AM
peeling stickers on an '07 panzerkfw Honda FireBlade 9 03-01-2008 4:38 PM
Quick! Oil Capacity on 954..w/ filter BigTimmyRydesFast Honda FireBlade 2 02-10-2005 10:03 PM
