battery dies on high beam - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 09-27-2008, 3:32 PM Thread Starter
When i take my 929 out for a ride for about half an hour or more... if i stop and try to start the bike again the battery is too low to fire the bike up. this only happens when i ride with my high beams on, otherwise it works good. any ideas of what the problem could be?
Jakemmi is offline
post #2 of 7 Old 09-27-2008, 3:37 PM
Quoted: 198 Post(s)
Reputation Power: 25
Re: battery dies on high beam
Check the stator and the votage regulator.
lanbrown is offline
post #3 of 7 Old 09-27-2008, 4:12 PM
bjay51d's Avatar
+1
bjay51d is offline
post #4 of 7 Old 09-27-2008, 4:14 PM
High beam draws more current than low beam.
If it _only_ happens on high beam then I'd be guessing your stator is not quite keeping the battery charged enough.
The battery may be going bad or it could be the stator or regulator.
post #5 of 7 Old 09-27-2008, 4:25 PM Thread Starter
ok... i'll check that at some point and post what happened once i get around to that.
Jakemmi is offline
post #6 of 7 Old 09-27-2008, 7:16 PM
Quoted: 198 Post(s)
May I suggest you taje the tools with you on all your rides? The reason being; it isn't going to start when you are out.
lanbrown is offline
post #7 of 7 Old 09-28-2008, 3:20 AM
If you don't use high beams it's not a problem though and you shouldn't be using them that much anyway?
battery dies quickly on my f3 mefistofeles666 Honda CBR 600 7 08-19-2008 1:46 PM
High Beam Indicator silverback Honda FireBlade 0 07-18-2008 10:30 PM
480 lb woman dies on couch. WetShrub Off-Topic 15 08-20-2004 12:01 PM
Headlight (R) high beam and rear (R) tail light: Problem!! CBR929Junkster Honda FireBlade 10 07-09-2004 5:54 PM
High beam adjustment Joel Honda FireBlade 9 08-04-2003 7:44 PM
