Noise - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 09-27-2008, 8:21 PM Thread Starter
Noise
It just happened while I was riding, I'd shift from neutral to first and it would engage hard it would make a high pitch squeal. Anyone know what this is or what to do? It only happens every once in a while.
K89052 is offline
post #2 of 4 Old 09-29-2008, 4:37 PM
Re: Noise
was this while moving or from a stop?
08cbr1000000000 is offline
post #3 of 4 Old 09-29-2008, 10:28 PM Thread Starter
Re: Noise
It was when I was at the stop light shifting it to first gear. I was told to adjust the clutch. Just need to know which way to turn the knob or adjust it from the bottom of the cable.
K89052 is offline
post #4 of 4 Old 09-30-2008, 11:06 AM
Re: Noise
You should be able to fit a nickel in between where the clutch lever touches the mount, before you feel tension when pulling in the lever. When you adjust the bolt that the clutch cable goes through, you should be able to see the clutch lever move.
Rattling noise under load, power surges when noise stops 107 Honda FireBlade 22 07-09-2012 4:22 PM
clunking noise when going forward. Noise back again!! anthonyl Honda FireBlade 26 09-28-2008 8:16 PM
Hissing Noise ? RLVampire General Discussion 6 09-09-2008 6:02 PM
Motor noise? robert200015 Honda FireBlade 20 03-02-2007 11:56 PM
Transmission noise??? 93CBR60022 Honda CBR 600 4 04-17-2006 2:33 PM
