Electrical Gremlins... - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 09-28-2008, 5:37 AM Thread Starter
I''m very confused over this one. I took the front end of my 1998 918 to fix / check the horn. I now have real Gremlins in there.
The lights no longer work and the indicators are stuck on. The horn still doesn''t work either. If I turn off the lights the indicators then work fine, but the horn still doesn''t work.
Anyone got the slightest incling as to what is going on? I've checked fuses, broke and re-made all connections, checked and cleaned battery connections...relay failed?
Any thoughts MUCH appreciated as I am well and truely stuck!
Many thanks
Craig
918onE is offline
post #2 of 7 Old 09-28-2008, 7:03 AM
macca9540's Avatar
Quoted: 50 Post(s)
Reputation Power: 270
Send a message via Skype™ to macca9540
Re: Electrical Gremlins...
Craig, all these symptonms sound like a flat battery or a bad earth maybe. Was everything working OK before taking off the front end. Does it start and run OK and when it's running do the indicators work?
I started off with nothing and still have most of it left.
A closed mouth gathers no feet.
macca9540 is offline
post #3 of 7 Old 09-28-2008, 7:36 AM Thread Starter
Hi Macca?
Thank you for your advice. I thought the same, that's why I cleaned the battery terminals.
Yeah, starts and runs perfectly. I rode it to my parent's garage where I took it apart. Driving me mad now! I went to fix the hornand now have no indicators or lights!!
Grrrr! So many things I should be doing and now I have a broken bike!!
Indicators (and lights and horn) are the same whether the bike is running or not.
Bizzare.....
918onE is offline
post #4 of 7 Old 09-28-2008, 10:20 AM Thread Starter
I've now spent all day on this and it's driving me nuts!
I think I'm going to have to resort to having a bike without a horn or lights!!
918onE is offline
post #5 of 7 Old 09-28-2008, 11:25 AM
I wouldn't worry about the horn but the lights would be annoying.
Have you tested the relay?
I know on the 929 all three relays (lights, starter and fuel pump) are the same so you can just switch them to confirm if one isn't working.
Since the horn isn't working either maybe you've cut a wire somewhere.
post #6 of 7 Old 09-28-2008, 11:28 AM
I just noticed the indicators are stuck on.
I'd check your earthing as well.
You can run a wire directly from an indicator back to the battery negative and see if that fixes it.
post #7 of 7 Old 09-30-2008, 3:54 PM Thread Starter
Hi Bladeracer
Thanks for your posts, I have spent another evening on it and have got nowhere. I have stripped a large amount of the wiring loom from the tape / insulation and can't find anything suspect.
I'm thinking now that it is in the lighting loom since if either the fuse for the headlamp (20amp) or horn/sidelight (10amp) is in there are strange symptoms - indicator display lamp on. The indicators themselves are not on.
If I turn on lights whilst bike is running I loose the tacho, If I run a frsh earth to tacho it works again.
If lights are off and I press 'passing light' I get a buzz from one of the relays.
Neither horn or lights work.
Grr!
Have tried swapping relays about - dip and full beam - no joy.
Have stripped and re-build bar switch unit - no joy.
Damn thing!!!
Any further suggestions much appreciated!
918onE is offline
electrical questions.. dagnasty Honda CBR 600 0 11-28-2007 1:30 AM
Electrical question... championsound Honda RC51 0 11-18-2007 1:33 PM
Electrical Problem austinlh Honda CBR 600 3 11-16-2007 7:18 PM
F'in electrical gremlins NinerPilot Honda FireBlade 2 09-14-2003 10:19 PM
Electrical problem Mattxp800 Honda FireBlade 4 06-01-2003 5:05 AM
