08 Throttle cable fitting - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 10-02-2008, 2:55 PM Thread Starter
Reputation Power: 12
Has anyone out there fitted a throttle cable to an 08 blade and can give me some pointers before I go for it
Rich22 is offline
post #2 of 6 Old 10-02-2008, 4:31 PM
Re: 08 Throttle cable fitting
No, but I am curious why you would be doing it so soon?
post #3 of 6 Old 10-02-2008, 7:38 PM
https://www.fireblades.org/forums/hon...eed-parts.html
redcbr1000rr is offline
post #4 of 6 Old 10-04-2008, 4:32 AM
Rich: did ya buy the HRC quick throttle or you replacing the OEM ones ?
Russ
Deathace is offline
post #5 of 6 Old 10-05-2008, 4:41 AM Thread Starter
Russ
I went with the oem ones as its mainly road use, its seems its around a 2 hour job to fit them, looking forward to that good thing is i now know this bike inside out it takes me around 5 mins to strip the fairings
Rich22 is offline
post #6 of 6 Old 12-23-2008, 8:21 AM
Have just done this on the weekend. Hardest part was getting the lower butterfly cable out and then in.
Was easiest when working on the left side of the bike with a hand under the frame (working the underside of the butterfly attachment point), small screwdriver in the other hand, and good looking assistant holding the torch from above.
Wont be able to do it working from the top.
Fairings were off already, so have to strip down to underside of airbox etc - good couple hours work.
Adjust up the tensions on the cables, then check that the butterflies dont move with the handle bars turned either lock.
This model has the metal throttle housing where the threads are different sizes, so cant go in backwards which is pretty handy
Rob500 is offline
throttle cable help timmeh Honda CBR 600 6 07-10-2008 6:10 PM
Throttle cable replacement pmpaluda Honda CBR 600 0 05-21-2008 11:54 PM
Throttle Cable Godti Honda FireBlade 7 03-01-2008 12:45 PM
Throttle cable question??? prkiller Honda FireBlade 5 03-14-2004 6:51 PM
