Bazzaz or Power Commander ?? which is better - Honda Motorcycles - FireBlades.org
post #1 of 19 Old 11-16-2008, 9:47 AM Thread Starter
i was looking at this BAZZAZ PERFORMANCE Z-AFM SELF MAPPING KIT
or a PCIII anyone know what would be better
kagmyster00 is offline
post #2 of 19 Old 11-16-2008, 11:23 AM
Quoted: 198 Post(s)
Reputation Power: 25
Re: Bazzaz or Power Commander ?? which is better
Both provide the same core functionality. The Bazzaz you can have traction control though; the PCIII you cannot.
No matter which you go with, you will need a dyno to tune it. If not, they are both a waste of money.
lanbrown is offline
post #3 of 19 Old 11-16-2008, 2:04 PM
Reputation Power: 59
Never heard of the BAZZAZ... IMO I would stick to the PC.
+1
Twincam is offline
post #4 of 19 Old 11-16-2008, 2:28 PM
Quoted: 198 Post(s)
The Bazzaz is better if you want the additional options. The founder has been in the ECU side for many years. In the AMA series the factory Suzuki team has used his expertise for years and when they used TC before it was legal; that was Bazzaz as well. They are new to the consumer but their products are tried and true. The PC is nothing special.
lanbrown is offline
post #5 of 19 Old 11-16-2008, 2:41 PM
Reputation Power: 39
I'm stickin with the good ole PCIII
WyoJames is offline
post #6 of 19 Old 11-16-2008, 3:22 PM
Reputation Power: 12
Go with the Bazzaz.
red08 is offline
post #7 of 19 Old 11-16-2008, 4:02 PM
Quoted: 198 Post(s)
That's the problem; they're old. Old technology mainly because they didn't have competition and instead of using new electronics they go with the old tech. Imagine if all companies did that. Your mobile phone would have vacum tubes in it.
lanbrown is offline
post #8 of 19 Old 11-16-2008, 5:42 PM
How about a third option the Motty AFR tuner. Take a look at it here.
I have one in my GSXR-1000 and it works great. Best part is it tunes itself without the need of a dyno. It constantly tunes the bike for any changes in condition like air cleaner getting dirty, new pipe installed, change in weather etc. The Bazzaz is not a true self tuning unit, it builds a log or map of suggested changes and the user must then connect a PC and retrieve the data then change the map.
The Motty does this automatically.
D.Nac is offline
post #9 of 19 Old 11-16-2008, 7:20 PM
Quoted: 198 Post(s)
Unless the Motty has changed, it is not plug and play; more like splice and pray. You also need to have a bung put in the exhaust system for the oxygen sensor.
lanbrown is offline
post #10 of 19 Old 11-17-2008, 10:04 AM
Need an O2 bung for the bazzaz also and yes you need someone with skills at splicing wires and soldering or you can make your own plug and play like I did for my GSXR, You can see it here.
If you dont want to mess with that you can always go the splice route the steps for that are here
D.Nac is offline
post #11 of 19 Old 11-17-2008, 12:34 PM
Quoted: 198 Post(s)
Or got with a plug and play system. Get a map done and you don't have to worry about the O2 sensor.
lanbrown is offline
post #12 of 19 Old 11-17-2008, 1:43 PM
That was a very clean install. How long did it take you to round up the spare harness parts, and do the actual installation?
IF I knew everyone was as capable as you, I'd feel comfortable making stuff that wasn't plug n play. But most people really suck at wiring. There have been many times I was asked to check out a customers bike to find wire nuts in the ignition wiring. I've seen people cut the battery ground wire off for weight savings. There are a lot of reasons I would never recommend people to do stuff as complicated as the installation you did.
Then there is the satisfaction thing. If I spent $500 on it, I hate having to spend another couple of days trying to round up parts to get everything to install properly. I like to pull the piece out of the box, have all the parts needed in the box, and have it on the bike as quickly as possible. I design my electronics like that , I wish the rest of the aftermarket would do the same.
brads955 is offline
post #13 of 19 Old 11-17-2008, 4:43 PM
I purchased an entire wiring harness from ebay prior to buying the Motty unit, the wiring harnesses are available from people that replace the stock harness with a race harness (no lights etc). I got the ECU connector from a company sample ,however I have also obtained them, very cheaply, from smoked ECU units on Ebay. You are right that part is a bit of a pain. The actual install took about 5 hours (and 5 beers) going very slowly and double checking every wire.
I wish the rest of the aftermarket would make everything plug and play too. In fact I almost passed on the Motty because of the non-plug and play issue. I spoke with the owner of the company and asked about the possibility of PNP. The issue is that they are a small company and all the motorcycles that the Motty uint can work with represents a multitude of connectors. Honda uses a different ECU connector than Suzuki and Yamaha uses yet a third. The 600s in some lines have a different connector than the 1000s.
I researched the development of a PNP solution to market for the Mottyand I found it was just too expensive. Because the connector manufacturers require a minimum number of connectors to be purchased at a time and then that is multiplied by the number of bikes to build it for and you can see how expensive it could get very fast.
The reason I ended up purchasing it is becasue it really is the best solution for real time auto tuning of a motorcycle which is the units greatest strength.
However the real time auto tune capability requires mutliple signals from the ECU that the other units do not require thus making it a more involved install.
If you think of a way to make it PNP let me know, I believe there is a huge market potential for these units if PNP beomes a reality.
D.Nac is offline
post #14 of 19 Old 11-18-2008, 6:09 PM
Reputation Power: 17
My buddy has had nothing but problems after installing the bazazz on his R1. It even took out his digital gauges somehow. And yes it was professionally installed. I would stick with the PC till they work all the bugs out of the bazazz.
BigBassTurd is offline
post #15 of 19 Old 11-18-2008, 9:37 PM
Quoted: 198 Post(s)
Maybe it is a Yamaflaw issue? I know people who have used the Bazzaz on Honda's and Suzuki's and have had no issues. Then again, peole have gotten a bad PC as well.
Define professional install? You can go and have an alarm installed by a "pro" and I would call the job they do, sh!t. I would never use crimps; but good old solder and heat shrink tubing.
lanbrown is offline
Power Commander 3 or Power Commander 3 USB Ben K Aftermarket Perfomance Parts Reviews 3 11-05-2008 3:00 PM
Power Commander III or IIIr? JeepinJeff General Discussion 5 06-23-2007 9:12 PM
Which exhaust sounds better, Micron or Twobrothers? ruffryden4life Honda FireBlade 8 10-18-2006 5:22 PM
Which is the overall better bike? VIVID1 Honda FireBlade 34 06-19-2004 8:16 PM
Which power commander should I get?? dtf7 Honda FireBlade 4 03-31-2004 8:53 AM
