08 blade tyre pressures? - Honda Motorcycles - FireBlades.org
post #1 of 12 Old 11-20-2008, 1:03 PM Thread Starter
hi allprobably an age old question should i inflate my tryes to what i says on the tyre wall or what it says on the swing arm sticker bit like the plate on a car? cheers in advance
dev435 is offline
post #2 of 12 Old 11-20-2008, 1:51 PM
Re: 08 blade tyre pressures?
The pressure on the sidewall is the _maximum_ load pressure.
It is not the recommended pressure.
The correct pressure is on the bike or in the owner's manual.
post #3 of 12 Old 11-20-2008, 3:57 PM
I think this could be down to personal choice too. I use what the bike recommends, but if it is warm and sunny (uk weather) then I will drop the pressures down to as low as 30 front and rear. This softens the carcass which in turns raises the temp and more grip. Or this is how I understand it, and what I have read, it work for me. Soft tyres wear out quiet quick though, but I find I can use Michelin Pilot Road 2CT's and raise and lower the pressure depending on weather and mood.
........... Hoody
Hoody is offline
post #4 of 12 Old 11-21-2008, 11:43 AM
Reputation Power: 41
As Hoody says, all personal taste mate. 99% of sportsbike manuals will tell you to run standard pressures of 42psi rear and 36 psi front.
FWIW, this summer I ran approx 38R 32F and she handled like a dream on the OEM BT015s. Gonna get some Michelin Pilot Power 2CT off my tyre contact this winter ready for next year. Don't need them yet but they are cheaper to pick up this time of year.
splatty is offline
post #5 of 12 Old 11-21-2008, 11:48 AM
For the very simple reason that modern sportsbikes run similar sized tyres and weigh similarly.
The correct tyre pressure is the pressure required to achieve the tyre's design _shape_ dependant on the amount of weight on it.
While it is common practise to adjust tyre pressures to alter the way the tyres work the correct way is to set the tyre pressures to their optimum and adjust the suspension until the tyres are working properly.
post #6 of 12 Old 07-06-2009, 12:05 PM
I have a cbr 900 rr sc 33, what tires presure i must have?
serginno is offline
post #7 of 12 Old 07-06-2009, 1:24 PM
Originally Posted by serginno View Post
I have a cbr 900 rr sc 33, what tires pressure i must have?
36psi front and rear.
post #8 of 12 Old 07-06-2009, 1:33 PM
Reputation Power: 59
...and rear? I thought 42 rear was universal on most sport bikes?
Twincam is offline
post #9 of 12 Old 07-06-2009, 1:38 PM
I just pulled the numbers from the manual :-)
It all depends on the weight on each tyre. The pressure is what keeps it at the designed profile.
post #10 of 12 Old 07-06-2009, 1:40 PM
Ahh ok, how many manuals does one have?
Twincam is offline
post #11 of 12 Old 07-06-2009, 1:43 PM
Something around 150 last time I checked :-)
post #12 of 12 Old 07-09-2009, 6:52 AM
Thanks for your help!!
serginno is offline
Tyre Pressures pauls Honda CBR 600 3 06-01-2008 5:04 AM
Recommended Tyre Pressures & Oil Grade Tim Poole Honda CBR400RR 5 05-19-2008 1:09 AM
Tyre pressures blackpool ben Honda FireBlade 5 06-06-2007 8:24 AM
tyre (tire) pressures for track days ndj Honda FireBlade 38 05-04-2006 2:42 AM
Tyre Pressures Seltorque Honda FireBlade 3 04-25-2006 11:29 AM
