2002 954 headlight not working?? - Honda Motorcycles - FireBlades.org
post #1 of 17 Old 11-20-2008, 9:34 PM Thread Starter
I have a 2002 954 and the headlight is not working, the bulb is good the fuse is good, is there a relay or something that im missing before i have to trace the entire system? has anyone else had this problem?
2002954 is offline
post #2 of 17 Old 11-20-2008, 9:55 PM
Re: 2002 954 headlight not working??
Do you mean all three globes aren't working?
post #3 of 17 Old 11-20-2008, 10:26 PM Thread Starter
all 3 lights are not working. turn signals work fine breaklights work fine there is no power at the highbeam switch either.
2002954 is offline
post #4 of 17 Old 11-20-2008, 10:27 PM Thread Starter
dang ... and no power at the lights... so im assuming the ground is good but no power to check it with.
2002954 is offline
post #5 of 17 Old 11-20-2008, 11:20 PM
Reputation Power: 12
Send a message via AIM to on1wheel01
First def check the ground test light neg to batt positive that will narrow that down
on1wheel01 is offline
post #6 of 17 Old 11-20-2008, 11:40 PM Thread Starter
i dont have the schmatic i have used the volt meter but it didnt get me very far.
2002954 is offline
post #7 of 17 Old 11-21-2008, 12:23 AM
Reputation Power: 87
Are you getting no lights at all? If only high and low beam are not lighting up but all the other lights work you might want to check this out.
https://www.fireblades.org/forums/hon...eadlights.html
NWBackwoods is offline
post #8 of 17 Old 11-21-2008, 7:57 AM
sscottab's Avatar
Reputation Power: 17
the same thing happened to me about a month ago the same symptoms that you are having, it is your starter button on the kill switch wiggle it or seperate the switch and clean and lube the swich with a spray lube and you can also try pulling the switch out some to see if you get your lights back. the reason you dont have lights is that the switch cuts power to the headlights to give more power to the starter when starting the bike. if lubing it doent work might need a new switch but alot of manufactures have the same problem on alot of different bikes.
2002 CBR954RR
scott
www.itriderz.com
sscottab is offline
post #9 of 17 Old 12-06-2008, 9:23 AM
sscottab's Avatar
did you get your headlights working.
2002 CBR954RR
scott
www.itriderz.com
sscottab is offline
post #10 of 17 Old 12-10-2008, 11:19 PM
flea954rr's Avatar
had the same problem a while back and posted this:https://www.fireblades.org/forums/hon...t-problem.html
flea954rr is offline
post #11 of 17 Old 03-26-2015, 9:09 PM
I just had this same problem. I cracked the kill switch case and found a small wire solder was broken. I resoldered and bam lights were back to working. Quickk easy fix and im sure shop would have cost about 100 to 150 and it actually only took about 30 mins worth of work and sprayed WD40 on cable pulleys for throttle and now isn't so stiff. Hope this helps someone out.
TX2002CBR954 is offline
post #12 of 17 Old 11-15-2015, 12:53 PM
Heeza Y Zasch
unslow1's Avatar
Quoted: 388 Post(s)
Reputation Power: 59
I feel like such a dope. I've been working on "The New Kid" for two days now (took off every piece of plastic again, test'd every connector, followed every harness, double and triple-checked each bulb, took apart the LEFT control block, QUADRUPLE-CHECKED the relay) then put the whole thing back together, got a 5gallon gascan & a book of matches...
...then did something I should've done in the FIRST place. I logged on Fireblades.org and SEARCHED!
yup. sticky starter button. flicked it out, and voila! LIGHTS
thank you Fireblades.org
unslow1 is offline
post #13 of 17 Old 11-15-2015, 6:16 PM
Quoted: 711 Post(s)
Reputation Power: 102
Fireblades.org, it's not just for posting pics
IanDoohan is online now
post #14 of 17 Old 11-15-2015, 6:48 PM
Heeza Y Zasch
unslow1's Avatar
Quoted: 388 Post(s)
pot... kettle...
unslow1 is offline
post #15 of 17 Old 08-23-2018, 6:29 PM
bringing this post back to life... anyways my 03s headlight doesnt work high beam does turn signals dont work and brake light stays on any ideas? also rpm gauge doesnt go pass 2k
jayprick16 is offline
929 Headlight not Working nomad13RR Honda FireBlade 39 04-10-2010 8:46 PM
Help headlight not working GypsyRebel General Discussion 7 10-03-2008 1:51 PM
02 954: trip odemeter not working. GATABITES Honda FireBlade 10 04-11-2008 9:17 PM
Still not working ! ! ! ashtanga Honda FireBlade 4 04-06-2007 7:19 PM
1995 CBR600 headlight/turn signal not working RADEoN Honda CBR 600 4 03-17-2007 12:37 PM
