spit test/down 1 cylinder - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 11-21-2008, 8:11 PM Thread Starter
i did a spit test on my headers and found 1 cylinder is not firing. and its the cylinder i used to check for spark on a previous problem. im sure i may have put it back together incorrectly some how. is it critcal to torque the sparkplugs on a motorcycle? and if so does anyone know the specs?
trav is offline
post #2 of 5 Old 11-22-2008, 4:41 AM
Re: spit test/down 1 cylinder
No, it's not critical but the specs are 12Nm or 9ft/lb.
Check the coil is on tight.
If it's still not firing try swapping the coil with another one to determine if it's the coil that's the problem.
post #3 of 5 Old 11-22-2008, 11:11 AM
Reputation Power: 17
What is a spit test? I'm picturing someone spitting on thier tire to see if they have a leak. Excuse me if thats a newber questions, but I've never heard that term before.
BigBassTurd is offline
post #4 of 5 Old 11-22-2008, 11:13 AM
Spitting on the headers.
If it doesn't steam off immediately the cylinder isn't firing.
post #5 of 5 Old 11-22-2008, 12:52 PM
Wow spits almost like duct tape. It's got 1001 uses. From cleaning your visor, checking for leaks and now non-firing plugs. What will they come up with next. Thanks BR for the insight, easier then removing the plugs to do a spark test. Man I always have to do things the hardway.
Oil spit Bruce Kent Introductions 3 09-22-2008 8:44 AM
anyone in the central nj area that can drive down with me for the drivers test? beerock Eastern USA 8 06-02-2008 6:06 PM
Cylinder Head Fastrr Honda FireBlade 2 05-26-2007 11:18 PM
Master Cylinder Chekman Honda FireBlade 8 02-02-2006 1:40 PM
Cylinder Problem JamesEarl15 General Discussion 4 05-03-2005 11:55 AM
