'94 CBR 900RR Backfiring - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 11-24-2008, 2:01 PM Thread Starter
Hey guys,
So I came home Friday night from College for Thanksgiving week, and I started up my bike. There was fuel pouring out everywhere. My friend and I noticed it was coming from the carbs, so we narrowed it down to the o-rings on the fuel tubes that go into the carbs from the fuel lines. We replaced those and it there is no leak. Before this happened, my bike used to have a power decrease in the 5-8,000 rpm range or so, and then it would kick back up. Now after taking the carbs apart to replace the o-rings, the powerband has completely changed and I get a whole ton more power and it seems to be going the way it should be. It's no longer whimping out on me, however, now when I let go of the throttle, or downshift, it starts to backfire. Because my friend dropped my keyes under the tank the last day I was home in August, he came over a few weeks ago to take the tank off to get them, and he called me up asking where a hose should be attached that goes from the front of the air filter. I don't remember seeing a loose house before when I was working on it this summer, but when I looked at it on Saturday it was there. It just goes around the air filter and leads to nowhere. Also, there are some carb vent tubes that go to a plastic housing, and it has a port for the same size hose as the loose one, but there is no way it can reach it. Basically I'm trying to get rid of the backfiring, and thought I'd give as much info as possible to the circumstances. Thanks for any help and advice!
Boilermaker is offline
post #2 of 4 Old 11-24-2008, 5:32 PM
Re: '94 CBR 900RR Backfiring
Just sounds like your running a bit rich, probably explains the increase in power also. It is probably just a bit of unburned fuel igniting in the exhaust. You probably inadvertantly adjusted your carbs while tinkering, dont forget you will need th balance them as well.
I am not 100% sure, but the hose sounds like the drain from the air filter. If it is, it should have a bung in the end that needs to be removed every once in a while to drain off any water that might build up in your airbox, I might be way wrong on that but thats how it worked on a few of my old bikes.
NorthSide is offline
post #3 of 4 Old 11-24-2008, 5:35 PM Thread Starter
Oh ok yeah that might explain it. I'm also having problems with my idle now. I've adjusted it a few times with the idle speed control, but it doesn't always cut it. If I'm going for a while at higher RPMs and then come to a stop, say a red light, the idle will go to around 1100, and then as time goes on continuously drop until it kills the motor. It happened all day yesterday. I couldn't find the hose or even the other hose housing on my Hane's Manual. It's just puzzling! Thanks for the help I'll probably have to take the tank off anyways so when it comes to that I'll post pictures of what I'm talking about.
post #4 of 4 Old 11-24-2008, 5:40 PM
Yeah, sounds like the carbs are out of balance. Dodgy tickover is a dead giveaway!!
'94 CBR 900RR Frame Sliders Boilermaker Honda FireBlade 0 11-02-2008 5:47 PM
94 cbr 900RR tail section help xxnightraven73x Honda FireBlade 20 04-29-2007 2:09 PM
WTB wiring harness for 94 cbr 900rr peternorth195 Wanted 0 12-20-2005 6:58 PM
94 Blade: Rough idling and backfiring from cold dymagblade Honda FireBlade 0 10-24-2005 8:57 AM
93-94 CBR 900rr Value? Opinions Needed rennspeed Honda FireBlade 10 05-17-2005 10:21 PM
