929 Relay BUZZING..WTF? - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 11-25-2008, 8:35 AM Thread Starter
I went out a few weeks ago to go to work on the bike and when I turned the key the headlight relay started buzzing ( I had my hi beams on when I parked it). But The high beam wasn't on. I turned it off but have the cluster was still dim? I tried the turn signals and the turn signal relay started buzzing and the lights did not work correctly? I replaced the relays and still the same thing. I check the turnsignals bulbs, ok. I checked the fuses, ok. Anyone have this happen before?
PS I have two new relays for sale!
Evan 929RR is offline
post #2 of 8 Old 11-25-2008, 8:54 AM
Re: 929 Relay BUZZING..WTF?
you sure it's the headlight relay? when you unplug it does the buzzing go away?
MACI4LIFE is offline
post #3 of 8 Old 11-25-2008, 10:26 AM Thread Starter
Yep. I just don't know what's causing it to buz? The same with the Turn signal relay? I took the left control apart but the high beam switch isn't serviceable. There was a clicking sound in the right side of the tail section when I cycled the high beams on and off and got better for a bit but then got worse and the clicking wasn't as loud? I know this week I'm going to clean the starter switch and look at the high beam switch?
post #4 of 8 Old 07-07-2012, 2:16 PM
How much do you want for the turn signal relay
Padraspencer is offline
post #5 of 8 Old 07-07-2012, 2:20 PM
Reputation Power: 113
He's probably sold them in the 4 years since that post.
Sky91 is offline
post #6 of 8 Old 07-07-2012, 2:26 PM
Thanks I didn't even pay attention to that
post #7 of 8 Old 07-09-2012, 9:00 AM Thread Starter
Actually I have not...I think (it's been four years). Send me your info to [email protected] and I will look tonight. I think I do.
post #8 of 8 Old 07-09-2012, 2:27 PM
Awesome !!
Sky91 is offline
01 929 fuel cut relay Draylob Honda FireBlade 0 08-24-2008 2:00 PM
929 FUEL PUMP RELAY?? CHAR929 Honda FireBlade 3 05-24-2007 9:01 PM
rattling/buzzing sound on my 954 12 O Clock Honda FireBlade 6 02-26-2007 8:29 PM
A RELAY IS A RELAY CBR629 General Discussion 4 04-01-2004 3:03 AM
Break buzzing sound? MarkN929RR Honda FireBlade 5 12-07-2003 4:55 PM
