Please help! need exhaust experts! ^^ - Honda Motorcycles - FireBlades.org
post #1 of 14 Old 11-27-2008, 1:29 AM Thread Starter
i know i'm being real stupid to ask this type of question here, but i'm noob and need help; and thank you all in advance.
i have 2002 Honda CBR954RR,
and i saw this exhaust on sale but i have no idea if this will fit.
all i know is: this is a "Scorpion titanium slip-on" & has 2in id inlet and 20in mounting clips.
i was somewhat sure this will fit (it's just a slip-on after all... isn't it?? )
but i just had to be sure before i make that purchase hehe...
please help! Thank you!!!
1f312c13a3na3pc3l78bq8798db9ddc5a1c57.jpg‎
tk804 is offline
post #2 of 14 Old 11-27-2008, 2:49 AM
Re: Please help! need exhaust experts! ^^
If it's a slip-on then it probably isn't going to fit if you have a stock midpipe unless you make up a slip-on flange to sut.
post #3 of 14 Old 11-27-2008, 8:44 AM
Reputation Power: 36
It also looks like some original packing you have with it. Any part number on the package you can cross over?
denzee is offline
post #4 of 14 Old 11-27-2008, 4:11 PM
Reputation Power: 59
You would have to modify the exhaust as there is a huge cone that fits into the OEM can.
The 954RRs have three bolts that mount the exhaust can onto the mid pipes, then there is the exhaust hanger attached by one female allen key bolt.
Also, I believe the 929 and the 954 end cans are interchangable therefore meaning a slip on from a 929 should fit (please correct if wrong) but doubt a full system would.
Twincam is offline
post #5 of 14 Old 11-27-2008, 4:27 PM
CBR929RE's Avatar
Reputation Power: 39
929/954 takes a bolt on not a slip on. it won't work unless you change the midpipe.
a 954 can will work on a 929 midpipe if you cut the cone off but you have to cut it all the way down at the bottom. don't know about a 929 can on a 954 a I haven't tried it. full systems are interchangeable. Sato lists my system only for a 954 but it fits my 929 without any issue.
CBR929RE is offline
post #6 of 14 Old 11-27-2008, 6:38 PM
I thought both the 929 and 954 have the cone?
The cali pipe is different though - I know it has the O2 sensor in it.
Full systems are interchangable except that the muffler hangers are usually different.
post #7 of 14 Old 11-28-2008, 1:25 AM
CBR929RE's Avatar
yeah I assume they both do. I just know my stock system when I bought it already had a 2Bros can on it. I sold that and bought a stock 954 can just in case I needed to quite the bike down at the track. When test fitting the 954 can I had to cut the part that I assume was the cone even further down than it was already cut just to get the bolts through the flange.
and the muffler hanger on a full system would be the same wouldn't it? if its an aftermarket hanger then it just replaces the passenger peg, that's the same on both bikes. I have a Sato hanger and the package said 954 and ZX6R.
CBR929RE is offline
post #8 of 14 Old 11-28-2008, 1:32 AM
Reputation Power: 15
it wont fit if you have stock pipes you need to change the mid pipe you need to be looking for a pipe that says 'bolt-on' not 'slip-on' their is a very big difference in between the two
zero937 is offline
post #9 of 14 Old 11-28-2008, 4:02 AM
The passenger pegs are different on the 929 and 954.
I have been told both will fit both subframes but they'll sit at different angles. Unlikely to matter with an adjustable hanger but a muffler with a fixed support point probably won't line up with the hanger.
post #10 of 14 Old 12-01-2008, 2:58 PM
Check my gallery for a side view of my can, and you can see two of the three bolts that hold the can to the exhaust.
Look for an end can that is meant for a 954/929, would be much easier than having to modify your midpipes...
Twincam is offline
post #11 of 14 Old 12-01-2008, 3:00 PM
You won't find a slip-on to fit a 929/954 as they are a bolt-on muffler.
If you want a slip-on you either need a half-system to the HTEV or a full system or make up a slip-on flange that bolts onto the pipe first.
post #12 of 14 Old 12-01-2008, 3:15 PM
Sorry (Mixed up my terms)...
Yep you are correct - end can it is
Twincam is offline
post #13 of 14 Old 12-01-2008, 7:39 PM
CBR929RE's Avatar
ahh by full system I assumed you meant aftermarket not stock. most aftermarkets just use band clamps so the hanger isn't a big deal.
CBR929RE is offline
post #14 of 14 Old 12-02-2008, 3:25 PM
Send a message via MSN to shakey1378
i have a carbon micron that will fit, i have two threads on it here. im offering a trade or purchase depending on if u have anything i can use. email me if your interested
shakey1378 is offline
Need Stock Exhaust Drill Mod. Info Please! mlwinnig Honda FireBlade 4 04-04-2007 11:01 PM
PHOTOSHOP EXPERTS! I need some help... J.R.rider13 Off-Topic 6 01-08-2007 4:48 PM
Which exhaust please help? Xavi954rr Honda FireBlade 7 01-02-2007 7:57 PM
Need Help, Please, Please, Please BushrodW Honda FireBlade 9 06-20-2003 4:24 PM
