Poor fuel economy - Honda Motorcycles - FireBlades.org
post #1 of 30 Old 11-26-2003, 3:41 AM Thread Starter
Poor fuel economy
Hi people, chanced upon this board and found much useful information and knowledge here. Maybe someone can help me out?
Bike: CBR 929
Mods: Stock standard (boring)
Mileage: 50,000km (about 31,000 miles)
Problem: used to be able to travel about 260km per tank before reserve light comes on when commuting. Over the last 3 years, this decreased to 240km, then 220km, then 190km two weeks ago.
My bike is stock, apart from a K&N air filter. Throttle bodies have been synchronised periodically, and Iím on my 3rd set of plugs. Inspection of the plugs does not show signs of a rich mixture. Iíve been using the same brand of 98 octane petrol, and my riding style and environment (traffic conditions) has not changed over the years.
The manual says poor fuel economy may be due to a pinched fuel tube or faulty pressure regulator. The fuel tube looks just fine, but I do not have access to a fuel pressure gauge, so is there any way of finding out the problem short of getting a new pressure regulator?
Dealers in this part of the world suck big time. Most have no idea how to properly service/diagnose a big EFI 4 cylinder bikeÖ
ulysses_sc is offline
post #2 of 30 Old 11-26-2003, 8:44 AM
ND4SPD's Avatar
Reputation Power: 50
Re: Poor fuel economy
Have you ever changed your fuel filter? I don't know what kind, if any, cleaners they put in fuel overthere. Might not be a bad idea to run some fuel injector cleaner through there too.
ND4SPD is offline
post #3 of 30 Old 11-26-2003, 12:11 PM Thread Starter
The fuel filter's one of those things that I kept telling myself to change but never did. Will get one later this week.
Let's hope it's due to some simple reason and not the pressure regulator acting up...
cheers!
post #4 of 30 Old 11-26-2003, 12:23 PM
ND4SPD's Avatar
With that many miles and original fuel filter, it very well may be the issue. Does it run rough at all? Rough starts, anything?
ND4SPD is offline
post #5 of 30 Old 11-26-2003, 12:35 PM Thread Starter
Problem is it starts (ok, it takes a couple of cranks before it fires, but this should be due to a dirty air filter), idles and runs just fine. So there are no symptoms to speak of. Talk about not knowing where to start!
to add to the confusion, all four plugs sport a tan look. seems normal enough...
But the fast idle seems a tad high at 2K rpm during a cold start. It settles to normal idling speed (abt 1.1K rpm) when the temperature reaches 52 degrees celcius.
Does the fast idle of 2k rpm sound normal? Is there anyway to adjust this? The service manual does not seem to mention this part at all.
post #6 of 30 Old 11-26-2003, 1:41 PM
ND4SPD's Avatar
Fast idle is adjustable via a twist knob that comes out on the left side of the bike, just above the shift linkage. It's a black plastic knob, sorta looks like a sprocket.
The 2k rpm fast idle sounds normal, every FI engine does that(at some RPM).
ND4SPD is offline
post #7 of 30 Old 11-26-2003, 3:42 PM
sounds to me like you have become more acustomed to that torque and hp and are just getting on the gas that much harder?
i consider myself lucky to get 100 miles / tank on the 600rr.
Insignificant Member
freq is offline
post #8 of 30 Old 11-26-2003, 6:59 PM
Mavic's Avatar
Reputation Power: 17
Normal for low temps
The fast idle is right on the money. This morning, my outside temp was 52F and the fast idle kicked in until the water temp got to around 100F and then it settles down to 1250 which is where Honda suggested setting operational temp idle. My bike only has 7K on it and has done this from day one so don't worry about the fast idle during cooler days. Mavic
Mavic is offline
post #9 of 30 Old 11-27-2003, 5:42 PM
My warning light comes on at around 240Klicks & usually pull in for petro (87 octane) & take in around 12.8 or 13L. Have made record milage of 302Klicks & took in 15.8L. Have well over 55 Klicks on bike along with original spark plugs.
Possibly you are clocking a lot of milage in back roads & town which really guzzles up the fuel or are honky on the hwy at above max speed limts in 4th & 5th a lot. Must admit I also do a lot of honking n 5th cog yet above fuel milage.
Have a '97 Yamaha YZF600r that is pressed at the same speeds & a lot of milage in 5th cog still it give 293Klicks at 14.3L to 351Klicks & 16.8L
Smitty is offline
post #10 of 30 Old 11-27-2003, 7:14 PM
Zeeman's Avatar
Quoted: 4 Post(s)
Reputation Power: 22
Ever try setting the choke on a Kwakka? how does 5000rpm fast idle for warm up sound?
I love fuel injection and auto fast idle..
Z...
You're f%#&king up my Chi...
Zeeman is offline
post #11 of 30 Old 11-27-2003, 7:26 PM
I would 86 the K&N, as they become clogged (unrepairably) over time and require complete replacement (contrary to their marketing claims). They are prone to expanded foam emphysema (internal cells breaking down and retaining particles of airborne contamination on the cell lining).
I would invest the 38.00 US (don't know the conversion rate) for an OEM unit and check the fuel economy.
abtech is offline
post #12 of 30 Old 11-27-2003, 8:24 PM Thread Starter
Thanks for all the suggestions! Will try out the suggestions one by one to see if it helps. Although the bike feels alright, I'm just a little concerned with the decrease in fuel efficiency with all other variables being constant.
Thanks!
post #13 of 30 Old 11-28-2003, 12:15 AM
I'm still amazed each time we bring up milage on a bike, I've seen 208 on a tank once (before light came on).
I average 170-190km per tank. I didn't think I was goosing it much....
Be fast or be last.
asiliat is offline
post #14 of 30 Old 11-28-2003, 5:07 AM
Hmmm, it could be your riding style. I know when I am riding real hard I only get about 75-80 miles before the fuel light comes on, but if I am riding slow or commuting it dosn't come on till about 110 miles.
Other wise I would have to agree with the fuel filter going bad.
KIDRR is offline
post #15 of 30 Old 11-28-2003, 6:22 AM Thread Starter
I never bother with fuel mileage when riding hard or at the track, but I'm pretty sure my commuting riding habits are nowhere near as aggressive as my granny's driving, so that's why I feel there must be something wrong somewhere when the light comes on much sooner than it should when I'm riding like a wuss on the streets! ha ha
sense of humour @ google Proto Politics 31 02-02-2012 3:55 PM
