seized pistons - Honda Motorcycles - FireBlades.org
Closed Thread
post #1 of 21 Old 12-27-2008, 12:29 PM Thread Starter
seized pistons
anyone know how to free seized brake pistons on my 98 blade front calipers thanks
cbr66 is offline
post #2 of 21 Old 12-28-2008, 3:39 PM
Re: seized pistons
whenever i've had a bike with seized pistons, i take the pads out and cover the pistons in wd40, then get a clamp or piston spreader, and push the pistons back in, then pump them back put again, you may need to do this quite a few times to free them, once they are moving again make sure you use some brake grease on the pistons, to stop them from sticking again, also dont pump the pistons out to far as they may pop out, and keep the wd40 away from the discs and pads, and if there is any corrosion on the pistons use some fine wet/dry paper to remove it. If after doing all the above and they are still sticking the brakes may need a re-build...
the-corsaro is offline
post #3 of 21 Old 12-29-2008, 10:21 PM
Quoted: 2 Post(s)
Re: seized pistons
heat the calipers and pop the pistons out with compressed air and be careful they come out fast.
cbr_df is offline
post #4 of 21 Old 12-30-2008, 12:55 AM
Re: seized pistons
Don't use too much heat ! Had a guy do that to my caliper and he warped them. They were junk after that.
muscledude53207 is offline
post #5 of 21 Old 12-30-2008, 1:02 AM
Re: seized pistons
wd40 will swell the seals and make it worse
take em out and clean them..
if you need lube going back in just use brake fluid
NDMBlackBlade is offline
post #6 of 21 Old 12-30-2008, 10:48 AM
Re: seized pistons
I' ve never had a proplem with wd40 making the seals swell, , dont believe everthing you read, been using it for years, with out any problems.
if you use brake fluid to lube the pistons, as soon as it rains or you wash your bike it will be gone, and in the uk, with all the rain and salt, your pistons will be seized again in no time, which is why in the trade, we use brake piston grease, also known as red grease, and many other names, to stop them seizing again.
post #7 of 21 Old 12-31-2008, 2:38 AM
Re: seized pistons
if you use brake fluid to lube the pistons, as soon as it rains or you wash your bike it will be gone,(its only to get the pistons into the rubber seals,they shouldnt have anything on them) and in the uk, with all the rain and salt, your pistons will be seized again in no time, which is why in the trade, we use brake piston grease, also known as red grease, and many other names, to stop them seizing again.
I'm also in the trade.
are you working on buses???
I'm in Ireland you think you have bad weather
watching to much of that butcher Dr rod or whatever he calls himself on the TV (god i don't know how they can show his work on TV and pass it off as tips )
just strip clean and reassemble as they left the factory
if wd40 and bus grease are the answer why isn't it used leaving the factory
post #8 of 21 Old 12-31-2008, 5:54 AM
Re: seized pistons
ok ok calm down, as with most people you do it your way, and every one else will do it there way, as with most forums every one has different opinions on how things should be done, no need to jump down peoples throat when they give an opinion, all this im right your wrong BS, get of you high horse and stop talking to the little men in green hats, they are giving you bad advice, and what trade are you in, airline hostess, never used brake grease, ask any good mechanic they all use it.
post #9 of 21 Old 12-31-2008, 6:11 AM
Reputation Power: 21
Re: seized pistons
I've worked as a mechanic in a Honda shop for 10 years, and we always use brake grease, on the pistons, this stops them from seizing in the future, it also keeps them from getting corroded and it does not damage to the seals.
stevecbr1000 is offline
post #10 of 21 Old 12-31-2008, 6:36 AM
Re: seized pistons
At last, someone who knows what im talking about.
post #11 of 21 Old 12-31-2008, 9:57 AM
Quoted: 44 Post(s)
Re: seized pistons
I've always used that there red grease too with no problems, never used wd40 though. Its such a light oil it would soon evaporate I would have thought (waiting for a flaming!!). Older Yams were renowned for seizing pistons and the number of times we've stripped callipers isn’t funny!! One problem is that corrosion can build up behind the seals making them pinch the piston so no amount of grease/wd40 will cure the problem so its important to be sure this hasn’t happened (it never has on any of my Honda’s). Callipers can be split is necessary to gain better access for cleaning without needing new seals. I would completely strip, clean, grease and re-assemble both callipers if it were my machine.
machinehead is offline
post #12 of 21 Old 12-31-2008, 1:13 PM Thread Starter
Re: seized pistons
Thanks for suggestions The WD.40 idea worked. could copperslip be used as a brake grease ?
cbr66 is offline
post #13 of 21 Old 12-31-2008, 3:13 PM
nedro's Avatar
Reputation Power: 27
Re: seized pistons
NO!
BTW Anyone of you ever put a piston seal in a cup of WD-40?
If not, do it and then come back and tell us what you find.
Ride Red
nedro is offline
post #14 of 21 Old 01-01-2009, 2:49 AM
Re: seized pistons
Don't be a coplete dick man!!!
where do you work???
Would people outside your village have heard of it???
There is only one right way to do things!!
you ever bought brembo brakes or pvm ap etc...
none of them are greased up.
any grease copper or otherwise will only cause dirt to stick
come on so big mouth give us a little backround on yourself there
Originally Posted by nedro View Post
NO!
Maybe this guy should try that
post #15 of 21 Old 01-01-2009, 2:51 AM
Re: seized pistons
maybe thats why all UK imports have corroded brakes nuts and bolts all over them is it??
Closed Thread
Cooling fan Seized! Does the Rad need to come off, to take off the fan? marty_400 Honda CBR400RR 2 08-27-2008 6:38 AM
'94 CBR600: Seized engine, misfiring, then problems DISAPPEARED RaceDriverDad General Discussion 3 05-28-2008 11:20 AM
When are pistons unusable? Skater! Honda FireBlade 4 04-30-2008 2:15 PM
FS: JE 12.5:1 High Compression Pistons SilverBullet For Sale 2 01-23-2007 7:20 PM
Pistons whooped that ass deez Off-Topic 12 06-17-2004 10:02 AM
