02' 954 mods - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 12-31-2008, 7:40 PM Thread Starter
02' 954 mods
ok it's been a year since i bought it. time to do a few things here. looking at velocity stacks, filter, detentarm shift kit,ignition advancer. my question is im hearing of an air box mod. what would this involve? and what would be the best air filter to use? aslo thinking of a power commander and which one? i ride on the street. want to keep my drivability,but improve overall power. sometimes i do flog it threw the gears at redline. and top it out!!it has 8,000 miles,a harris titanium pipe. . any thoughts,suggestions ? thanks
sportmotob is offline
post #2 of 6 Old 12-31-2008, 9:18 PM
Re: 02' 954 mods
The air box mod is just removing the plastic flapper that is hooked up to the servo motor via a cable. Just take the airbox cover off, disconnect the cable and unscrew the parts from the air box base. This is a very simple mod. I have a BMC race air filter with a full Two Bros. It runs great but filters are mostly personal preference I think. As for the power commander, go with the PCIII USB.
IRISH MIKE is offline
post #3 of 6 Old 01-01-2009, 8:06 AM
sscottab's Avatar
Reputation Power: 17
Re: 02' 954 mods
the air box mod is easy just push the flapper down and pin it under the air inlet tubes, I have found doing the suspension mods was the upgrades that made the most differance on these bikes, most of the upgrades where done on my bike when i bought it, i relized how much they help when i rode a friends 954 his had no upgrades on the suspension, my forks have been redone, resrpung and revalved by the original owner. the ohins damper is a must on these bikes or a damper of any kind is needed i put a ohins on mine and love it. my rear shock looks different then the other 945 i rode, mine has adjustments on the top and the bottom and his has a fixed bottom and with mine set up for my weight it keeps the bike very stable in the twisties and on the straights, you can go faster on a bike that handles better then you can on a bike that has more hp and does not handle as good.
2002 CBR954RR
scott
www.itriderz.com
sscottab is offline
post #4 of 6 Old 01-03-2009, 8:19 PM Thread Starter
Re: 02' 954 mods
i set the sag on the front. help alot by doing that. and have been trying to tweak it a little more. it seems like it dives sharply into turns sometimes tho. what defference does doing away with the air box flapper acheive?
post #5 of 6 Old 01-03-2009, 8:54 PM
Re: 02' 954 mods
No difference at all. The flapper opens at 8000rpms so there's zero difference above that. Below that the flapper is closed which probably is more to reduce induction noise than anything else.
post #6 of 6 Old 01-04-2009, 4:59 AM
Reputation Power: 12
Re: 02' 954 mods
I have pinned down mine. There is no difference in power, but the engine has lost some of the jerkiness low down.
ag1s is offline
06 mods blackdog Honda Naked Sportbikes 9 08-25-2007 6:53 AM
Best Mods ashtanga Honda FireBlade 10 04-13-2007 7:38 PM
A few last mods SpookyjacK Honda FireBlade 0 04-01-2007 1:33 PM
Mods are Done! southpark460 Honda RC51 21 05-02-2006 7:26 PM
What Mods are you Going to do? hokoyo Australia 32 05-27-2004 8:27 PM
