spark plugs - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 01-21-2009, 11:44 AM Thread Starter
spark plugs
Ok, pulled the fuel tank to adjust throttle cables and replace a leaking fuel line and I realized that it would be a good time to replace the plugs. Bike has 11k on it and according to the factory manual, they should be replaced @ 8k miles. I'm replacing the air filter too. The plugs are pricey and I'm pretty sure that I read somewhere else, maybe this forum, that they arent due until 30k??? From others experience, when did you replace yours?
Frankly I don't have the cash to replace the plugs at the current rate and if I have bad info then I won't feel as guilty about not doing them now.
yeller929 is offline
post #2 of 8 Old 01-21-2009, 12:20 PM
sscottab's Avatar
Re: spark plugs
if they are ngk iriduim tip plugs you do not need to replace them till 30k that is when i replaced mine, the book states 30k for the 954 and i believe the 929 is the same.
2002 CBR954RR
scott
www.itriderz.com
sscottab is offline
post #3 of 8 Old 01-21-2009, 12:24 PM
Reputation Power: 12
Re: spark plugs
the maintenance manual recommends replacing the plugs on the 929 at 8k, 16k, 24k,....
firebladeking is offline
post #4 of 8 Old 01-21-2009, 2:54 PM Thread Starter
Re: spark plugs
It looks like Ill be pulling a plug...
post #5 of 8 Old 01-21-2009, 4:06 PM
Re: spark plugs
I must be honest, i didnt belive this but i just checked my 954 service manual and yip it states inspect at 16k and replace at 32K!! crazy considering the 929 manaual says inspect every 4k and replace every 8k
post #6 of 8 Old 01-21-2009, 11:51 PM Thread Starter
Re: spark plugs
They are iridium! 18k miles left to go. thanks for everybodys input.
post #7 of 8 Old 01-22-2009, 3:19 PM
Re: spark plugs
yeah just checked and the 929 has Denso IUH27D (iridium) as standard, but they still recommend replacement at 8K
post #8 of 8 Old 01-22-2009, 8:24 PM
Re: spark plugs
here is my experience. never checked plugs,had 1 come loose from vibration.stripped the head,$1000 later back running,you dont need to change them, but atleast check them every season to make sure they dont come loose.
eye toke is offline
Spark Plugs-What's best navyshooter Honda RC51 4 07-03-2008 5:21 PM
WTB 929 SPARK PLUGS IRISH MIKE Wanted 3 05-12-2008 8:30 PM
Spark Plugs? EvLTwiN Honda RC51 10 06-09-2007 11:36 PM
No spark at the plugs Wizard Honda RC51 6 04-24-2006 5:17 AM
