1999 CBR900RR Running out of gas? - Honda Motorcycles - FireBlades.org
post #1 of 12 Old 01-30-2009, 3:40 PM Thread Starter
Reputation Power: 11
Send a message via AIM to __DoPe_ShOw__ Send a message via Yahoo to __DoPe_ShOw__
Hey, I bought a 1999 Honda CRB900RR lastnight and it was running fine. Then I got half way home and it started to spudder like it was running out of gas. But I was on half a tank... I switched to reserve and it still did the same thing. The funny thing was that when I would hit a bump, not a soft one but a hard one, it would act right for a little bit then go back to spuddering... I put gas and it smelled like a toilet... Unfortunatly I didn't realize it till I already pumped the gas into the bike. So, whut could be making it spudder like its doing?
Another problem, the neutral light stays on unless I wiggle the harness that goes to it, could these problems be linked? Cause when its spudders the light flickers... Hmmm.... Any help would be appreciated...
__DoPe_ShOw__ is offline
post #2 of 12 Old 01-30-2009, 5:01 PM
Send a message via MSN to shakey1378
Re: 1999 CBR900RR Running out of gas?
sounds like 2 different problems. i would definately start looking for loose wiring. sounds like you could have some bad fuel. 9 outta 10 if you hit a bump and things start working for a second and not to mention the neutral light stays on there is some sort of electrical issue with the bike.
get a service manual if your taking this on yourself. do you know if the bike was sitting for a long time?
shakey1378 is offline
post #3 of 12 Old 01-30-2009, 5:06 PM Thread Starter
For a few weeks I think... Not that long... I can't see anything shorted with the tank on, but imma take the tank off and look. I hope nothing is screwed...
post #4 of 12 Old 01-30-2009, 5:18 PM
check your ground too.
post #5 of 12 Old 01-30-2009, 7:30 PM
Check your side stand kill switch too. For sure it is something electrical. It might be tricky to find, but at least it will most likely be a cheap, easy fix.
Skater! is offline
post #6 of 12 Old 02-01-2009, 12:44 AM Thread Starter
Ok, well I got the spuddering sorta fixed. I drained the carbs and ran it out of gas like 3 times just to make sure... I think something is still wrong with the carbs, maybe dirty or something. It still does it sometimes when I let off the throttle then hit it again... The neutral light goes off when I mess with the wire. I pushed it all the way on and I thought it fixed it. Not sure if it's the switch or not, $13.44 for the switch is cheap enough, I'll order one... Anyways, I love this bike, I'll post some pictures tomorrow sometime... Anyone got a good black leather Honda jacket for sale? Haha!!
post #7 of 12 Old 02-01-2009, 5:10 AM
Had the same problem with my 900RR and it was the fuel pump.
When I hit it with something (softly) it would work for two second but then shut down again.
Not saying this is your problem as well but just keep it in mind.
Dunc is offline
post #8 of 12 Old 02-02-2009, 5:02 PM
His 99 wouldn't have a pump. I would go through the carbs and give them a good cleaning. On the 99's, is the switch on the left side near counter sprocket like the older models?
cbr900racer77 is offline
post #9 of 12 Old 02-02-2009, 5:06 PM Thread Starter
Yea, I got the spuddering issue fixed, but the neutral light still stays on... And it is annoying... But I am almost certain that it is the switch itself...
post #10 of 12 Old 02-02-2009, 6:03 PM
You could also have kinked or blocked off vent lines for the tank or the carb bowls, or a kink in the fuel supply line, or a sticky carb float.
Dynojettech is offline
post #11 of 12 Old 02-03-2009, 6:10 AM
Quoted: 28 Post(s)
or a speck of dirt it a carb jet requires strip clean and reassembly - not difficult.
other than that, your eletrics just sound like bad connections or possible broken wires so simple inspect decide which and should be ok to fix.
manuals are available as PDF files through Google but links are not supported on here iirc.
machinehead is offline
post #12 of 12 Old 02-03-2009, 8:16 AM Thread Starter
Yea, I think the switch harness is bad, cause sometimes my kickstand switch works and sometimes it doesn't... I'm going to change it... I got the manual in PDF, and I didn't even look at it yet. Then I lost the cushions on the gas tank to the frame... Blah... Ok, time to order small parts!!!
Considering buying a 1999 CBR900RR CBRBethesda Honda FireBlade 20 08-18-2010 1:31 AM
1999 CBR900RR series motor into a 1995 frame RDRACR Honda FireBlade 1 11-11-2008 2:38 PM
1999 cbr900rr possible spun bearing?? rdr7586 Honda FireBlade 6 08-21-2008 9:02 PM
selling bodywork 1999 CBR900RR judge9554 For Sale 2 07-30-2008 11:46 AM
will 2000 cbr900rr rear shock fit 96 cbr900rr? wylier18 Honda FireBlade 0 01-22-2007 1:06 AM
