954 front spring swap??? - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 01-30-2009, 8:48 PM Thread Starter
Hey all, I would like to swap the springs in the front on my 954 from stock .71 to 1.03(racetech). The honda dealer here says I need to change to a gold valving kit as well, as the standard valving won't work correctly with that big of change to the spring rate. Is this actually the case or is he just feeding me a line? Thanks for any input.
bigdannyb is offline
post #2 of 5 Old 01-30-2009, 9:13 PM
Re: 954 front spring swap???
He's trying to sell you a valve kit.
The spring has _nothing_ to do with the damping.
The spring supports the bike.
The valving adjusts the speed at which the fork functions.
post #3 of 5 Old 01-30-2009, 9:45 PM
Reputation Power: 12
I think there is an element of truth in the need for changing valving. A harder spring will produce greater forces requiring more damping to absorb.
In other words, for an impact of a given energy, a 30% stiffer spring will travel 30% less, thus the same energy will have to be absorbed over a 30% less distance, thus requiring more damping.
ag1s is offline
post #4 of 5 Old 01-30-2009, 10:03 PM
I was assuming he was going to the heavier spring because he's a really big bloke.
If he's a lightweight guy then it is quite likely he would lose fork travel and this would leave less time for the damping effect. I can't see how re-valving it would have much effect though.
post #5 of 5 Old 01-31-2009, 12:07 AM Thread Starter
Thanks for the input. I weigh 310 and need help in stopping the massive nose diving under breaking. Not looking for any performance gains in handling except under breaking. Just like to cruise with the option for speed from time to time.
954 rear spring swap bigdannyb Honda FireBlade 3 11-27-2009 10:46 PM
Toronto Spring Bike show and swap meet cravingmore Canada 1 02-26-2007 9:26 AM
2000 fork spring swap DarkStarCBR Honda FireBlade 2 02-23-2007 5:02 PM
Front Fork Spring Weight ? Spanky Honda FireBlade 11 06-16-2006 1:03 AM
Spring Swap on a Conventional fork? ccwilli3 Honda CBR 600 10 07-27-2004 11:37 PM
