954 cuts out - Honda Motorcycles - FireBlades.org
post #1 of 37 Old 02-23-2009, 9:26 AM Thread Starter
954 cuts out
Hi there, I`m new to this and was wondering if anyone could help me!!
My 954 blade (2002) cuts out after crusing along 60/70 mph opening throttle to overtake then when slowing down/ backing off the throttle it cuts out like you've hit the kill switch and get a backfire when engine starts bk up which is straight away. The bike idles ok, so tick over speed is ok, also plugs, air filted and oil have been changed, and fuel filter is clean. Have cheched side stand switch and tilt switch which are also fine... oh and if you blip the throttle in 2nd 3rd etc and release clutch it also feels like your hitting limiter even if you only take the rev's to 6/7000 rpm. both red lights and Fi light come on.
Any help would be great!!!!
drayson is offline
post #2 of 37 Old 02-23-2009, 9:32 AM
Reputation Power: 17
Re: 954 cuts out
, mine was doing the same thing a while ago, i never found out what it was but it isnt doing it now so i have only clues. Check your kill switch and make sure connections are fine. Also check ur battery connections.
rokitt51 is offline
post #3 of 37 Old 02-23-2009, 9:35 AM
Re: 954 cuts out
Clutch switch maybe?
post #4 of 37 Old 02-23-2009, 9:37 AM Thread Starter
Re: 954 cuts out
The kill switch has been opened up and contacts cleand, and have just fitted a new battery about 2 weeks ago as one of my mates said that a low battery might be the cause. On the move the bike only cuts out at a speed of between 67 and 75mph, its got me puzzled.
drayson is offline
post #5 of 37 Old 02-23-2009, 9:39 AM Thread Starter
Re: 954 cuts out
Cheers for the reply Larry, How does the clutch switch work and forgive me but where is it lol
drayson is offline
post #6 of 37 Old 02-23-2009, 9:53 AM
Re: 954 cuts out
On the clutch lever.
I think it cuts ignition (it may only cut the start circuit though) so you can't start the bike in gear without pulling the clutch.
Try bypassing it and see if that helps.
I doubt it's the problem but it's easy to check and the problem definately seems electrical.
Actually, I just thought about it and the clutch switch can't cut the ignition so it must only isolate the starter circuit.
post #7 of 37 Old 02-23-2009, 9:56 AM
Re: 954 cuts out
Is this regardless of gear or revs?
post #8 of 37 Old 02-23-2009, 10:05 AM Thread Starter
Re: 954 cuts out
Have noticed its normaly when i'm in 5th or 6th gear, when I have just overtaken & slowing back down to around 70mph, or when riding at a constant 72 mph in either of these gears, it cuts out and back on again in seconds, just like youve hit the kill swith on and off. If you thrash the bike it seems ok, you can take the revs right up to max with no problems, only when backing off the throttle or idelling along do I get the fault. But also in 2nd or 3rd if you blip the throttle (try to lift the front end) it seems like you hit the rev limiter even at 6,7,8000 rpm, and you get the red lights on the dash.
drayson is offline
post #9 of 37 Old 02-23-2009, 11:26 AM
Administrator
Red Rider's Avatar
Reputation Power: 47
Re: 954 cuts out
Does the bike have a Power Commander?
Red Rider is offline
post #10 of 37 Old 02-23-2009, 11:39 AM Thread Starter
Re: 954 cuts out
No the bike hasn't got a power commander
drayson is offline
post #11 of 37 Old 02-23-2009, 12:44 PM
Reputation Power: 12
Re: 954 cuts out
Mine did that once before going down a hill like 60...i just pop started it and kept going. It was pretty random, hasnt done it since.
Cracker 954RR is offline
post #12 of 37 Old 02-25-2009, 12:02 AM
Re: 954 cuts out
Mine was cutting out too, but not in the exact same way because I couldn't identify what was causing it to cut off. My mechanic replaced the TPS and it happened again twice. He said to take it back but I thought I would just keep riding it till I get a better understanding of when it's doing it. It's now two months later and it has been running fine, but I haven't regained my trust back since I can't accept that the problem just went away.
Although, I did notice something recently- when I hit my High Beams there is a 2-3 second delay for the lights( also the Hi-Beam indicator) to actually fire up. This did not happen before.
Also how long should the "FI" signal stay on after the engine starts up? Mine stays on for bout 3 seconds then it goes away.
Hoser954 is offline
post #13 of 37 Old 02-25-2009, 1:39 AM
Reputation Power: 11
Re: 954 cuts out
It really sounds like a fuel related problem due to electrical. You're at high speed (sorta ) and then it cuts out, then back in.
I would focus on the fuel pressure regulator; if you rule that out, start checking out the injectors themselves. The regulator's job gets harder the faster you go (it has to increase the delivery rate to the injectors) and the way you describe the hard throttle/no throttle, seems almost like the system is starving, then catching up..
muddysteel is offline
post #14 of 37 Old 02-26-2009, 12:42 AM
Reputation Power: 15
Re: 954 cuts out
I second the TPS
sonik_fury is offline
post #15 of 37 Old 03-25-2009, 12:11 PM Thread Starter
Re: 954 cuts out
Cheers for the replys, sorry havent been on here for week or so but been away!!!! Bike has had a diagnostic check and nothing is showing up, and I am not getting and fault lights on the bike after I have had the cut out faults!!
Still getting the faults/cutting out, and now the bike cuts out in 1st if I pull away fast or hold the revs between 20 and 30mph... How do I check the fuel pressure regulator and the TPS? I'm now pulling my hair out with this damn bike lol.
drayson is offline
01 RC Cuts out ??? Brett Haven Honda RC51 6 01-14-2009 4:22 PM
HELP! Problem with FI , cuts off.... vamike23 Honda RC51 15 12-30-2008 5:44 PM
SP1 Just Cuts Out UKRC51 Honda RC51 1 11-11-2008 1:17 PM
929 CUTS OUT HELP PLEASE!!!!!! player80978 Honda FireBlade 11 08-01-2005 3:26 PM
Cuts showmethebombs Off-Topic 5 01-23-2005 9:18 PM
