954 CCT life? - Honda Motorcycles - FireBlades.org
post #1 of 2 Old 02-24-2009, 6:26 PM Thread Starter
954 CCT life?
i have ~29K on my 954 and it just started knocking loud upon startup around the center rear of valve cover and as the engine warms goes down to a mild knock but this sounds like coming from the front of cylinder head (perhaps 2 completely seperate knocks), i took it around the block to listen & also heard it make another larger knock/stumble while cruising about 45mph. I'm guessing its the cam chainer tensioner & i prolly could use a valve adjustment which i havent done yet? i talmost seemed like the knocking was from not getting enough oil at startup and then as soon as it warmed up the oil lubed it...
03' Blk/Tit CBR 954rr, Erion full system, PCIIIr, Scott's Damper, Vortex Frame Sliders, Galfer SS Lines, Rear Seat Cowl, flapper pinned.
vertical954rr is offline
post #2 of 2 Old 02-25-2009, 2:02 AM
Reputation Power: 11
Re: 954 CCT life?
29K miles, right? No valve adjustments? Yeah.. DEFINITELY time for valve adjust, especially if you didn't do one at 16k miles (which is the interval between valve clearance checks).. And when you do it, you'll probably find the exhaust side of things is more out-of-range than the intake..
muddysteel is offline
After Life jasonlakewhitne Religion 37 01-19-2009 1:55 PM
CBR 4 LIFE coffeeman690 Introductions 9 05-13-2006 4:45 PM
Life after HL2 BigRoy Off-Topic 9 04-08-2005 4:07 PM
New sea life? Jay Off-Topic 9 07-02-2003 6:17 PM
