RR7 BLADE EXHAUST COMPATIBILITY - Honda Motorcycles - FireBlades.org
post #1 of 3 Old 03-02-2009, 2:45 PM Thread Starter
Hi
Does anyone know if the standard OE exhaust for an RR7 is compatible with say an RR4?
(I assume its the same as thr RR6)
Regards John
jenuinejohn is offline
post #2 of 3 Old 03-02-2009, 4:07 PM
Reputation Power: 17
Re: RR7 BLADE EXHAUST COMPATIBILITY
should be... the aftermarket stuff is all 04-07..
ldavis is offline
post #3 of 3 Old 03-02-2009, 5:09 PM
hi John,
ive just recently put a yoshi slip on onto my 05 1000rr, it came with the option of using one of two hangers supplied. one of them made the can lower than the other when mounted. i accidentally put the 06-07 hanger on first and my can was touching the tail tidy. when i looked at the hanger for the 04-05 model i saw that the hanger had slightly longer brackets coming down from it. this then gave my can the little bit of room between it and the tail tidy. apart from that everything went straight on, it also said on the box it was for 04-05 model and 06-07 model. however ive read on here that there is a difference with the location of the pulleys for the valve, mine were attached to the original so i just uncoupled them and cable tied them up out of the way. maybe you should post a thread on the aftermarket pages to double check.
cheers ron
ronmorgan is offline
The RIGHT exhaust for my new Blade OU812 Honda FireBlade 7 03-10-2009 3:56 AM
GP exhaust for 06/07 Blade bleedred General Discussion 8 02-11-2009 10:19 PM
Exhaust for 929 blade mill929 Honda FireBlade 6 12-24-2008 10:58 AM
Windscreen help please? 93 Blade compatibility? gmoooney Honda FireBlade 1 08-29-2008 12:05 AM
Exhaust for 06 Blade ogdawodu Honda FireBlade 10 02-21-2007 9:47 AM
