02 cbr 929 fuelpump wire - Honda Motorcycles - FireBlades.org
post #1 of 9 Old 03-04-2009, 4:59 AM Thread Starter
WHERE DO THE 3 WIRES FROM THE 3PIN PLUG RUNNING FROM THE FUELPUMP
END UP AND WHAT DO THEY CARRY 2BROWNS 1 GREEN I REWIRED MY LIGHTS AND I THINK A CUT A WIRE IN THAT HARNESS ..BECAUSE BEFORE I STARTED
THE FUEL PUMP ENGAGED WITH THE KEY TURNED AND THE SWITCH ON
.....WHEN I WAS DONE IT DIDENT SO IF I RUN ALL NEW WIRES SINCE ITS ONLY 3 OF THEM ITS NOT TO MUCH WK AND COUL HELP ME ANYONE THAT MAY HAVE SOME INFO PLEASE CONTACT ME
ANDRE
[email protected]
imdadrdre is offline
post #2 of 9 Old 03-04-2009, 7:56 AM
Re: 02 cbr 929 fuelpump wire
If it's '02 it's a 954 as the 929 was only '00/'01.
What do you mean by where do the wires end up?
They go from the fuel pump to the harness connector.
You can check if the wires are good by checking for continuity.
If you have continuity then they're okay.
If you did cut a wire maybe just try reconnecting it?
post #3 of 9 Old 03-04-2009, 1:43 PM
Send a message via MSN to shakey1378
first get a sevice manual. did you inspect the area you thought you cut a wire? trace the wire back to the source, if you cut it i would think it would be visible?
please turn caps off, its hard to read your post.
shakey1378 is offline
post #4 of 9 Old 03-04-2009, 6:35 PM
Administrator
Red Rider's Avatar
Reputation Power: 47
This thread has the wiring schematics for the 929...
https://www.fireblades.org/forums/hon...tml#post126392
Red Rider is offline
post #5 of 9 Old 03-05-2009, 3:21 PM
Yes they carry 2 Browns, a Brown with a black tracer, a solid Brown. & a Solid Green. Hope this helps.
sicspeed is offline
post #6 of 9 Old 03-05-2009, 3:26 PM
Reputation Power: 62
does the starter turn over? but with no spark or pump? have you checked the lean angle sensor? if it is unplugged or off (hanging or upside down(if youre workingon it)) it will stop the bike from firing up... mite help?
Back on the road again!...
fighter954rr is offline
post #7 of 9 Old 03-10-2009, 12:47 PM Thread Starter
where is the lean angle sensor
post #8 of 9 Old 03-10-2009, 12:47 PM Thread Starter
and sorry its an 01 not an 02
post #9 of 9 Old 03-10-2009, 12:51 PM
do you have pics? im not too sure on the 01... that would be a 929 i think....
3 wire turn signals to 2 wire LED lights zachsauto Introductions 16 03-27-2014 1:22 PM
Wire for mid or top end? temperedtim929 Honda FireBlade 1 02-18-2009 11:38 PM
TPS wire on 929 Eckl Honda FireBlade 0 01-09-2008 12:23 AM
RPM wire? pavetim Honda FireBlade 1 08-07-2006 6:38 PM
2 Wire turnsignal hookup to 3 wire schott Honda CBR 600 5 06-13-2006 8:42 PM
