DIY Valve Adjustment - Special Tools? - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 03-05-2009, 11:13 AM Thread Starter
I was looking at my shop manual about doing this myself (to save $350), and it says I need a "cam chain tensioner tool". Is this accurate? Can I use something else to accomplish the job? WHY do I need to use one for the adjustment?
Any help would be appreciated.
Thanks.
KillerPunkin is offline
post #2 of 6 Old 03-05-2009, 11:38 AM
Re: DIY Valve Adjustment - Special Tools?
You have to remove the cams to adjust valve clearances.
Removing the cams means you'll need to compress the tensioner to reinstall it afterwards.
You can grind a flat-bladed screwdriver down so it fits in the hole.
post #3 of 6 Old 03-05-2009, 12:26 PM
Reputation Power: 11
And don't forget your triple-jointed thumbs and index fingers! That hole in the '03 blade is pretty hard to reach - be sure to use a small enough "tensioner" (the flat headed screwdriver is great!) to reach inside the hole of the tensioner (the bolt/nut is yet another interesting thing to deal with).
muddysteel is offline
post #4 of 6 Old 04-08-2009, 2:21 AM
The tensioner tool is really easy to make out of a piece of 1mm thick metal.
I found the piece at Home depot for $1.59 canadian, thats free in US dollars....
you need to release the tension on the cams so your measurement is accurate. You have to measure to determine what new shims you will
put in.
Trendkiller is offline
post #5 of 6 Old 04-08-2009, 2:59 AM
Quoted: 6 Post(s)
Reputation Power: 26
Indeed! Rep for you!
ghbzorro is offline
post #6 of 6 Old 04-08-2009, 5:28 PM
I was changing my cam chain tensioner when I check and adjust the valve clearanses. New cam chain tensioner was delivered with tensioner stopper. Stopper was just metal plate what was cut to T-shaped form. It was wery handy when I remove cams from my bike. One valve was over the tolerance in 10 000 miles driven RR8. I adjust all the valves to the middle of tolerance.
Zuhnu99 is offline
Valve adjustment -Do it yourself ,or pay ? Renegade929 Honda FireBlade 64 08-21-2009 7:41 PM
Special Tools needed for fork work? mharrison Honda RC51 0 04-07-2008 4:56 PM
Valve adjustment when do I need to do it 929 joeysack Honda FireBlade 4 09-28-2006 6:04 PM
Special tools needed for Valve Clearance check/adjust? chkaotic Honda FireBlade 7 02-20-2006 12:59 PM
Valve Adjustment Help. Repsol_69 Off-Topic 1 02-29-2004 8:30 PM
