929 rear spring yellow vs white - Honda Motorcycles - FireBlades.org
post #1 of 15 Old 04-17-2009, 12:08 AM Thread Starter
Reputation Power: 12
Ok i'm sure someone will blast me for asking but i'm going to any way. Is there a difference between the yellow and white rear spring for the 929, or did they just feel like painting them different colors? If so could you tell me what the difference is and the benifits of each.
stiffer56 is offline
post #2 of 15 Old 04-17-2009, 2:42 AM
Re: 929 rear spring yellow vs white
Maybe try searching as I remember reading a discussion about this some years ago.
I don't recall but it think it was finally determined to be the same spring.
If the wire diameter and coil pitch are the same I'd assume they're the same weight. It's possible they might be treated differently though.
post #3 of 15 Old 04-17-2009, 12:28 PM Thread Starter
I tried searching and didn't find anything. I have two shocks and both springs. That is why I was wondering if there is a different.
post #4 of 15 Old 04-17-2009, 3:53 PM
If you have both take measurements.
Or you can measure their rates yourself with a bathroom scale and a car jack or press. The rate is simply kg/mm (not sure if there is a lb/in in the US or not). I usually compress a spring in 10mm increments and record the load required and then average it. Modern springs are usually linear but a progressive spring will require an incremental increase in load for each 10mm of compression.
post #5 of 15 Old 04-17-2009, 6:37 PM
white was 2000 yellow was 2001 ? can anyone with these bike years verify their colour of rear shock?
my erion has a yellow spring
but it's most likely just a colour difference.
MACI4LIFE is offline
post #6 of 15 Old 04-17-2009, 6:48 PM
Nope but I can tell you my '00 spring is white.
post #7 of 15 Old 04-17-2009, 7:05 PM
Administrator
Red Rider's Avatar
Reputation Power: 47
My '01 was yellow...
Red Rider is offline
post #8 of 15 Old 04-18-2009, 12:02 AM
so far it looks like the colour depends on the year.
post #9 of 15 Old 04-18-2009, 2:09 AM
Reputation Power: 19
My 01 is also Yellow.
Dre-929 is offline
post #10 of 15 Old 04-18-2009, 1:06 PM
my 00 is white!
Gaz929RR is offline
post #11 of 15 Old 04-18-2009, 1:18 PM
verdict is in.
2000 = white spring
2001 = yellow spring
My scientific theory has thus been concluded. lol
post #12 of 15 Old 04-18-2009, 2:07 PM
Reputation Power: 11
Ive had both, and my 2000(RR-Y) had a white spring and my 2001 (RR-1) had a yellow.
firebladeking is offline
post #13 of 15 Old 04-18-2009, 3:59 PM
verdict is in.
2000 = white spring
I tend to agree :-)
Now we just need to work out if they're the same spring just different colours :-)
post #14 of 15 Old 04-20-2009, 5:16 PM Thread Starter
Well the white one is on my bike and it is a 2000. When I tear my bike down to powder coat everything I will have to see If I can measure the spring rates of the two and let everybody know.
post #15 of 15 Old 02-28-2014, 6:13 AM
Old thread but did we ever figure out if they are different? I have wondered this one for years!
snakeskinner1 is offline
954 rear spring swap bigdannyb Honda FireBlade 3 11-27-2009 10:46 PM
WTB: Shifter side rear set & black/white rear cowl tran_man Wanted 1 12-09-2005 9:44 AM
Rear seat Spring for a 929 hill929 Honda FireBlade 3 03-08-2005 3:58 PM
How do you adjust the spring on the rear of a 954..... HyrePower Honda FireBlade 5 10-15-2004 2:58 AM
anyone want to trade bodywork?-have 00 red/white/purple fireblade want yellow/black charkly Honda FireBlade 10 09-29-2004 12:04 PM
