R-77 full system 08 blade - Honda Motorcycles - FireBlades.org
post #1 of 16 Old 04-17-2009, 3:04 AM Thread Starter
does anyone have this system? How do you like it? Is it bad in the long run to throw an exh. system on a bike without tuning it? I dont really want to have to buy a power commander and deal with the fuel consumption. Is the slip on more cost effective or are the stock headers really weariness enough to change?
MC
Mcalvert1000 is offline
post #2 of 16 Old 04-17-2009, 4:33 AM
Reputation Power: 11
Re: R-77 full system 08 blade
MC
yes, I have got it, it is titanium/carbon version. I love it. If you will not get the power commander AND tune it on the dyno then your bike wil run VERY lean. Try More Power Racing - Car Truck and Motorcycle Accessories - they also do price match. I bought everything from them (exhaust, power commander and BMC air filter).
I got approximately 10 bhp more across whole range of rpm, the flat spot at around 4 thousand rpm is gone. The fuel consuption is worse, 5-10 % less miles from the tank than before. Many places where I had to ride in the first gear are fine in the second gear now and bike also runs cooler.
Blackadder is offline
post #3 of 16 Old 04-17-2009, 7:12 PM Thread Starter
word. ive been hearing very mixed results as i have been looking for an answer to this. some say the stock pipe is the best and that there is no more power to be had because of the valve system (even though it doesnt make much sense for the topend). A cross section diagram of the stock pipe makes me wonder though. Im no engineer but it doesnt look like its the absolute best design for an exh. sys. it kinda goes into a chamber then the valve decides which hole it comes outta. This makes me think all rough surfaces (hinge for the valve) might cause some turbulence making room for improvement. am i on the right track here?
post #4 of 16 Old 04-18-2009, 1:31 AM
The stock exhaust system has to comply with noise and emission regulations. It is not bad, but the valves (there are two inside) system creates uneven torque increases up to 6000 rpm. I think you might be almost on track understanding why after market systems can achieve better results: you get smooth bigger diameter pipes flowing more gasses. If you go for some significantly lighter system than the stock one you can not only increase the bhp but you will save a few pounds of weight too.
post #5 of 16 Old 04-18-2009, 7:21 AM
Reputation Power: 15
I havnt got a yoshi but have a Akrapovic full system which should be around the same figues but can say that the original down pipes flow realy well and the difference on this model between aftermarket and original is between 8-10 more at the very top end with a PC111.So in the UK about 169-172BHP at the wheel depending on dyno and conditions but the big change is the the fueling which will improve the throttle response and mid range wollop and completely agree with blackadder on his previous posts.Heres my dyno sheet on a tight engine.
001.JPG‎
Stu748R is offline
post #6 of 16 Old 04-18-2009, 12:08 PM
and here is my graph:
Power.jpg‎
post #7 of 16 Old 04-18-2009, 1:20 PM Thread Starter
damnation. im convinced. thats quite impressive guys.
post #8 of 16 Old 04-27-2009, 4:27 PM
Do you have the stock dyno to compare against? This is the first Yoshi dyno i have seen, i made very similar numbers with a full arrow and bmc filter/tune. Within 1 hp and .2 tq.
fastrob691 is offline
post #9 of 16 Old 04-27-2009, 4:30 PM
Reputation Power: 39
If you're not going to get a power commander, stay with the stock exhaust
WyoJames is offline
post #10 of 16 Old 04-27-2009, 4:58 PM
I am sorry I do not have the stock chart, I have seen one and heard about other results to be somewhere from 157 to 164 bhp. I think this board got a thread somewhere with the stock dyno chart.
post #11 of 16 Old 04-28-2009, 11:23 AM
Cool its always nice to compare your own stock to modded to see the gains, mine was 157 with the Z-bomb(gives back the top end which is stock in europe) and 168 with system and tune.
post #12 of 16 Old 04-28-2009, 1:00 PM
Seconded .. This setup is fantastic... and I get 50mpg
boysie is offline
post #13 of 16 Old 04-29-2009, 9:14 AM
hu? 50mpg?
TroyBoy30 is offline
post #14 of 16 Old 04-29-2009, 9:40 AM
Originally Posted by TroyBoy30 View Post
hu? 50mpg?
Yes that's correct... 50 miles per UK gallon riding around normally, i e, town work and cruising around 80 to 90 mph-ish.. Full Akrapovic and PC111
boysie is offline
post #15 of 16 Old 04-30-2009, 8:18 AM
i'm averaging 32 per US gallon
Full Race System Blade 08 - Requirements DukeCBR2008 Honda FireBlade 15 07-17-2008 8:03 PM
954 D&D Exhaust System. Full System, NEW reallyBIGfuzzy For Sale 2 06-18-2008 12:40 PM
WTB: 954 full system proze Wanted 0 06-05-2008 5:22 AM
Full system for 929 or 954 superbs929rr Wanted 2 03-31-2008 8:56 PM
Looking for a full system. Lucky929er Honda FireBlade 8 06-28-2004 10:08 PM
