clicking noise when breaking 929 blade - Honda Motorcycles - FireBlades.org
post #1 of 22 Old 04-20-2009, 12:06 PM Thread Starter
Reputation Power: 11
Hello hope someone can help
I have resently noticed a click coming from the
Bars just as you come too a stop. Only happens when
I break hard and there is a lot of weight on the front
.it almost feels like the bars move but not if you know
What I mean.
I just upped the front And rear pre load and this started
But I can't see why that would cause this. I am new to big bikes and
Am brakeing harder and later with every ride witch may be why I
Only just noticed it
Any ideas ?
blade9292001 is offline
post #2 of 22 Old 04-20-2009, 12:19 PM
Reputation Power: 17
Re: clicking noise when breaking 929 blade
Bearings might be getting loose/worn. Sit on your bike hold the front break and rock back and forth hard. If you feel play in the neck(bars moving forward and back) then the bearings are probably worn.
BigBassTurd is offline
post #3 of 22 Old 04-20-2009, 12:27 PM Thread Starter
I am fairly sure there is no movement I ment you can hear the click and feel
It I will get them checked.thanks for that
post #4 of 22 Old 04-20-2009, 12:33 PM
May be the rotors. You have floaters and sometimes they move. Also check and make sure that the bolts for the rotors and axle are good and snug.
rokitt51 is offline
post #5 of 22 Old 04-20-2009, 8:33 PM Thread Starter
I have noticed the discs do click a little bolts are all tight but it does seem too come from the bars. How do I check the head stock bearings do I need
A special stand or it a rear stand and trolly jack ok if so where's the best jack point .
I can't feel the bars move but can feel the click through.them
post #6 of 22 Old 04-22-2009, 12:07 PM
What I mean.
Any ideas ?
haha, sorry but this is a little funny.
Every bike does this. This is normal. It's when you are in gear, squeeze the clutch, and do an "emergency stop". Put your bike in neutral and try again, it won't happen. I don't know the exact reason, but I guess it comes from the clutch.
thelastosirus is offline
post #7 of 22 Old 04-22-2009, 11:47 PM
Check the Rotor Buttons and see if they are loose. Reach down and grab the rotor with your hand and try to move from side to side if they move and you didn't install full floating rotors (aftermarket) your rotors need to be replaced. Also check the Head set barrings sometimes they need to be tightened and re-packed
TXhooligan is offline
post #8 of 22 Old 04-23-2009, 6:18 AM Thread Starter
Thanks for you help with this . I'm certain that the discs are ok and are Honda parts.
Can anyone tell me the best way too check the head bearings
post #9 of 22 Old 04-23-2009, 6:43 AM
Did you even do what I told you to try? If it was your head bearings, then you would feel a bump through handlebars when you apply the front brakes, not a clicking sound. But to check your head bearings, stand in front of your bike and straddle the front wheel. Grab the handlebars, and while holding the brake, pull the bike forward and backward. If it pops, then your bearings are shot(or loose).
But once you try to duplicate that clicking sound with your bike in neutral, you might be surprised.
post #10 of 22 Old 04-23-2009, 7:09 AM Thread Starter
I did try what you said mate and didn't stop it . And as I said it dose come through the bars
post #11 of 22 Old 04-23-2009, 7:37 AM
Ok..I missed that part. Now check the head bearings, if you can understand my instructions. It's also possible if they just started to go bad, tightening the nut up top will help some. But you're just buying a little more time by doing that.
post #12 of 22 Old 04-23-2009, 10:42 AM Thread Starter
No worries . Rite did what you said can't feel any movement but there is a kind of poping sound when I did it and also as the forks compress and rebound ?
post #13 of 22 Old 04-23-2009, 11:02 AM
You won't feel any movement, because the bearing might only be moving a few tenths of a milimeter. But you WILL feel the popping... The fork movement you can ignore. But it sounds like those bearings are shot.
post #14 of 22 Old 04-23-2009, 11:12 AM Thread Starter
Should I use tapered roller bearings or not is it an easy job
post #15 of 22 Old 04-24-2009, 1:33 AM
Not sure what you're asking... Use OE honda bearings. But it shouldn't be to hard if you do your own repairs and maintenence. You either need a certain type front stand, or suspend the front of the bike from a roof while on a rear stand. And you need a torque wrench for the tripple clamp nut. Other then that its pretty straight forward.
02 CBR 954 making slight clicking noise.... GATABITES Honda FireBlade 45 08-20-2018 11:11 AM
Clicking noise when start moving. danny_isr Honda FireBlade 5 10-30-2007 3:34 PM
CBR900 Clicking/ knocking noise......HELP please!! 96pearl900 Honda FireBlade 5 10-29-2007 6:51 AM
2000 blade ..clutch noise? BCMODCHIP Honda FireBlade 0 06-05-2005 3:47 PM
Clicking noise from the front Mavic Honda FireBlade 10 09-19-2003 10:03 AM
