Which jet kit to buy - 900RR - Honda Motorcycles - FireBlades.org
post #1 of 11 Old 04-20-2009, 6:46 PM Thread Starter
Any recommendations on a jet kit for my 98 900RR? I'm going to be cleaning and syncing the carbs, putting on a different exhaust and replacing the air filter. I would like to maintain my bike's excellent low-end and mid-range. Top speed isn't so important as this bike is mainly for commuting.
Is it even worth it to put in a jet kit or should I just keep it as is?
cbrsmurf is offline
post #2 of 11 Old 04-20-2009, 7:10 PM
Re: Which jet kit to buy - 900RR
What are you trying to address with the jet kit?
I haven't used a jet kit since 1990 but generally they're aimed at getting more peak power rather than midrange.
post #3 of 11 Old 04-20-2009, 7:19 PM Thread Starter
Yea, I don't know too much about jet kits I assumed they were more like power commanders or other EFI chips that let you adjust and smooth out your powerband however you'd like (of course it would much more involved turning screws on a jet kit rather than plugging a Power Commander into a laptop).
If I want to maintain the low/midrange, should I just stay with the stock jets?
cbrsmurf is offline
post #4 of 11 Old 04-20-2009, 7:22 PM
The midrange is a result of intake and exhaust restriction. To get peak power you open both up. To boost midrange you reduce them.
The jetting is purely to allow the engine to combust effeciently depending on how much and how fast the airflow passes through the chamber.
I'd wait and see how the bike is after you replace the muffler and then decide if it needs jetting to suit.
post #5 of 11 Old 04-21-2009, 2:13 AM
Reputation Power: 15
factory pro - apk, no contest
sonik_fury is offline
post #6 of 11 Old 04-22-2009, 6:29 PM
Factory Pro in mine--works great.
Helpful advice, get the other mods first, ie pipe, airbox or filter kit, ingition advance what have you, and then work with the jet kit. Any changes or moads relating to air/fuel system will require an adjustment in the jetting to get it to your liking. Be prepared to do some reading and experimenting till you get it right. I just changed full pipe systems again this year from Yosh to D&D again and needed to adjust things. Not real difficult, but will take some of your time to dial it in right.
Once you get what you are going to put on it, post it for some ideas for other's setups.
over_40 is offline
post #7 of 11 Old 04-23-2009, 5:51 AM
Reputation Power: 166
If you're changing the air filter and exhaust then you'll probably need a re-jet as the 900's are notorious for not taking these changes too well without it. This was certainly the case for my bike.
I went with Dynojet, purely because there's a Dynojet centre with a rolling road in the town where I live. Also, the chap that owns it goes to my gym, and is a lot smaller than me - which might have been useful if they screwed it up!! (just kidding - anyhow they did a good job, runs lovely now).
Dangerous Des is offline
post #8 of 11 Old 04-23-2009, 6:12 AM
Do you have before and after dyno graphs by chance?
post #9 of 11 Old 04-23-2009, 6:29 AM
Well I do, somewhere.... they're buried in the garage I think! They're also hard copy only... I'll see if I can a) find them and then b) take a photo of them, as I don't have a scanner
post #10 of 11 Old 04-23-2009, 6:31 AM
There was not much of a power gain - 1-2hp if I remember - but before I got it fitted I had a problem when rolling off / back on to the throttle where the bike would hesitate before going again - not good when entering corners! It stopped doing this as soon as I got it re-jetted.
post #11 of 11 Old 04-23-2009, 4:16 PM Thread Starter
very helpful info all, thanks
cbrsmurf is offline
Headlight conversion 95 900RR-98 900RR jamilrahman Honda FireBlade 10 11-18-2013 8:22 PM
1998-99 CBR 900RR face to 1996-1997 CBR 900RR mech5398 Honda FireBlade 26 02-04-2013 4:47 AM
'93 900rr/ '95 900rr interchangeable? Benno Honda FireBlade 2 05-04-2007 11:33 AM
95 900rr w/ 96 900rr engine cyruschen Honda FireBlade 1 09-09-2006 12:19 AM
'98 900RR brakes for '96 900RR ap10046 Honda FireBlade 4 06-09-2006 3:02 PM
