engine mulfunction light - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 04-24-2009, 6:26 PM Thread Starter
Hello all
I have installed a two bothers can and I am having the orange PGMFI light on all the time, any suggestions on how to solve this?
ton304 is offline
post #2 of 5 Old 04-24-2009, 7:23 PM
Re: engine mulfunction light
When you removed the stock can and disconnected the flapper cable, did you role the cable accuator wheel on the servo under the seat back to the at rest position, if not this will give you an alarm
maverik is offline
post #3 of 5 Old 04-25-2009, 1:23 AM Thread Starter
how do I turn it to its reset position? which way and how many turns please?
ton304 is offline
post #4 of 5 Old 04-25-2009, 7:26 PM
First of all, did you remove the cable that went to the stock can, and, if you did, then you should know about the servo wheel. i remember rotating it one quarter turn clockwise to get the cable out and then turn it back counter clockwise one quarter turn. it turns hard so go easy,, here's a link to a video on how to do it. http://www.youtube.com/watch?v=uAk7c...eature=related
Also if you removed the O2 sensor from the mid pipe when you installed the two bros system, did you put it back in, this will give you an alarm,,good luck, and ride safe,,
maverik is offline
post #5 of 5 Old 04-26-2009, 2:50 AM Thread Starter
Hi maverilk its the 02 sensor, i am buying an oxygen eliminator since. I am getting 2 long blinks and 3 short and I was told it means the 02 sensor.
ton304 is offline
engine light, exhaust swap 08 1Krr.. ??? upchuck419 Honda FireBlade 25 03-06-2013 11:04 AM
Bazzaz ZAFM turns on engine management light Robbo Honda FireBlade 16 09-13-2010 5:00 AM
F1 light on solid engine splutters 929 lordwarkworth Honda FireBlade 1 07-17-2008 9:12 AM
help my 05 1000rr pgm-fi light & idicator light flashes 3slow 4 fast? impervious Honda FireBlade 9 02-05-2007 1:01 PM
Flickering engine light on 929 Big_Bird Honda FireBlade 2 01-19-2007 11:27 PM
