02 CBR954 Sprocket Question - Honda Motorcycles - FireBlades.org
post #1 of 12 Old 04-24-2009, 8:54 PM Thread Starter
Im about to buy my first 954, I sold my RC51 and going to Liter.. The bike has 19k miles 2 Brothers bolton and stuff And i got him to $3800 but what are the pros and cons of that -1 Front Sproket...?
-1 Front sprocket with vortex rear sprocket and DID gold chain(520 conversion)
^^ Whats the pros and cons of that and is it any good in your guys experince..?
Thelawyer is offline
post #2 of 12 Old 04-24-2009, 9:00 PM
Re: 02 CBR954 Sprocket Question
at highway speeds, u will be at ~6k rpm instead of 5k, so it will be louder
JSquier is offline
post #3 of 12 Old 04-24-2009, 9:03 PM Thread Starter
Thats the only differnce...? Thats actually pretty stupid in my opinion... No advantages?
post #4 of 12 Old 04-24-2009, 9:06 PM
Reputation Power: 12
Your accell will be a little quicker.....and you will lose a little top end. All n all it will be alittle more fun. Id look into a speedo heeler, your speedo is prob a little off.
Cracker 954RR is offline
post #5 of 12 Old 04-24-2009, 9:09 PM Thread Starter
Will it effect the milage on the bike? like make the more miles quicker? and will the MPH be higher or lower.. Like if it says im doing 80 ill actaully be doing what..?
post #6 of 12 Old 04-24-2009, 9:15 PM
sorry, i only did cons, yes, you will accelerate faster and your overall gearing will be a little different.
if you showed 80 now you might be doing 75, but with the sprocket, it would be 80 and 70
JSquier is offline
post #7 of 12 Old 04-24-2009, 9:40 PM
yes without the speedo healer the milage will stack up a little quicker. i believe the speedo healer is only around 110 bucks....this will correct everything for you.
post #8 of 12 Old 04-24-2009, 11:29 PM
You sold an RC51 to go to a liter?
Lowering the gearing allows you to reach higher revs at lower road speeds thus improving acceleration.
Your speedo and odo will read higher.
You will have a slight decrease in chain and sprocket life.
You will use more fuel.
Going to 520 with lightweight sprockets reduces driveline mass but any power gain would be hardly measureable. If you run a steel rear sprocket there's really no advantage swapping to 520.
The colour of the chain is irrelevant - you can get gold chains made of cheese if you wanted to - what matters is its tensile strength.
post #9 of 12 Old 08-05-2012, 8:39 AM
Reputation Power: 10
Wow I'm pretty sure this is the oldest thread I've ever seen resurected BUT, I'm doin a 525 -1+2 alum vortex and I'm broke, will a chain 8800 lbs be adequate? Has pcusb, full tune,k&n, handle header/two bros can, pair delete, flapper mod, and is stretched 6-8 inches so this will be a 150 link chain(SUB ? Is 150 long enough)
Willieonethou is offline
post #10 of 12 Old 08-05-2012, 8:54 AM
I don't know if the extra length is likely to affect it but 8800lbs is fine.
8" is an extra 13 links so I would expect 26-28 links longer than stock should be long enough.
post #11 of 12 Old 08-07-2012, 8:12 AM
How long is stock off the top or ur head?
post #12 of 12 Old 08-07-2012, 8:17 AM
Off the top of my manual it's 108 links ;-)
sprocket question full-onbikes Honda RC51 14 06-06-2009 9:35 AM
sprocket question SAK General Discussion 5 07-10-2008 8:33 PM
Sprocket Question bim Honda FireBlade 1 06-25-2005 10:16 AM
CBR929 CBR954 15t(-1) 520 front sprocket PrplHaz4 For Sale 0 01-19-2005 5:23 PM
One more Sprocket question? Hellfire666 Honda FireBlade 1 04-30-2004 1:06 AM
