2 long and 3 short blinks - Honda Motorcycles - FireBlades.org
post #1 of 16 Old 04-25-2009, 10:41 AM Thread Starter
Dear all
Does anybody know what 2 long and 3 short engine malfunction blinks means on the honda fireblade 2008? I have just put a two brothers and I got this code. any ideas guys please on how to elimenate this?
ton304 is offline
post #2 of 16 Old 04-25-2009, 11:45 AM
Reputation Power: 12
Re: 2 long and 3 short blinks
Possibly a fuel management error. is the slip on all you did???
Trimmed_Jennis is offline
post #3 of 16 Old 04-25-2009, 12:07 PM Thread Starter
I did the two brothers slip on the stock exhaust
ton304 is offline
post #4 of 16 Old 04-25-2009, 1:35 PM
Reputation Power: 21
you didnt disconnect the valve solonoid did you for exhaust flap?
if you left the cables on and tied them up out the way, you didnt make it to where the cables wont move freely?
GENERAL ROBERT E. LEE
Jetpilot07 is offline
post #5 of 16 Old 04-25-2009, 2:54 PM Thread Starter
no I left the servo motor connected under the seat, I tried moving it and it moves. anyone has any idea what this code means?
ton304 is offline
post #6 of 16 Old 05-06-2009, 7:53 AM
I have the same problem. Does it mean I need a commander?
osacookey is offline
post #7 of 16 Old 05-06-2009, 7:58 AM Thread Starter
I was told that it will be solved with an oxygen eliminator
ton304 is offline
post #8 of 16 Old 05-06-2009, 8:23 AM
Reputation Power: 36
Your 2 long and 3 short flashes translates to a code 23 which is not a valid code in the previous generation shop manual that I have, sorry. Any chance you are not reading it correctly?
denzee is offline
post #9 of 16 Old 05-06-2009, 8:52 AM
Quoted: 2 Post(s)
Reputation Power: 11
Dear all
you have an O2 sensor the the silencer & a motor driving the valve.
I think the motor has a special position after disconnection & before the engine is turned on for the ECU to establish its ref point. You should have been supplied with an O2 eliminator is your new cans don't have one.
I can try to find some info in my service manual later on if you don't get any joy
bonjo is offline
post #10 of 16 Old 05-06-2009, 9:07 AM Thread Starter
the ecu is recognizing there is something not connected so that is why its blinking
ton304 is offline
post #11 of 16 Old 05-06-2009, 9:17 AM
So what is not connected then. O2 or servo??
denzee is offline
post #12 of 16 Old 05-06-2009, 9:34 AM Thread Starter
the 02 is not connected, sorry for having confused you
ton304 is offline
post #13 of 16 Old 05-06-2009, 9:53 AM
The blinking light does not only indicate something disconnected. The ECM is getting a sensor reading it doesn't like. May be O2 or servo in this case.
denzee is offline
post #14 of 16 Old 05-06-2009, 1:57 PM
code 23 comes up as faulty 02 sensor heater....
honda3x23 is offline
post #15 of 16 Old 05-07-2009, 3:48 AM Thread Starter
I will inform you once the 02 eliminator arrives and I install it, I am hoping it will solve the problem. I keep you posted and thanks a real lot for your great help
ton304 is offline
red light 1 short 3 long 4 short ? when i turn the key on... bike runs tip top tho ? joshw Honda FireBlade 11 02-25-2009 6:35 PM
Fault Code: 2 short blinks... Mike725 General Discussion 0 04-24-2008 3:31 PM
Two Long and Three short Engine Code Help Duke_954 Honda FireBlade 9 02-21-2008 4:53 PM
Pazzo levers - Short or long? 01 929RR JeepinJeff Honda FireBlade 15 03-22-2007 5:50 PM
FI Light 35 blinks and now 34 blinks iujmulr General Discussion 7 01-16-2006 11:39 AM
