929 Fuel system issue - Honda Motorcycles - FireBlades.org
post #1 of 9 Old 04-25-2009, 9:20 PM Thread Starter
Reputation Power: 78
Hey Guys,
After 9000 miles, my first real issue. So this is whats up; sometimes the fuel pump wont prime = no start. When it does prime, the bike will start no problem, but tends to stall more than not, can be after 30 secs or 5 min. After turning the key, and flipping the kill switch, 3/10 times the pump will prime and itll start. I do have a manual and first I know i should get if it is getting voltage, which ill do tonight, but since it primes once in awhile im assuming it cant be that. When its running, it runs perfect. Now the question is, can it simply be a clogged fuel filter? Seems naive since the pump doesnt prime...Help please!
BurtonF166 is offline
post #2 of 9 Old 04-25-2009, 11:20 PM
Re: 929 Fuel system issue
Originally Posted by BurtonF166 View Post
Hey Guys,
If you're a rider that uses the kill switch instead of the ignition to stop the engine I would say it's the killswitch.
post #3 of 9 Old 04-25-2009, 11:28 PM Thread Starter
Ive heard of bad connections in the housing...every time I hit the switch, one of two things happens. 1) the pump primes as expected or 2) i hear a slight click and no priming, then 3 secs later, the red light and FI both turn off as though all is ready to be used.
post #4 of 9 Old 04-25-2009, 11:31 PM
The click is the relay.
post #5 of 9 Old 04-25-2009, 11:34 PM Thread Starter
Im away from the bike right now, but by the relay clicking, could i assume that its getting voltage? I mean, it runs, and i drove it 3 miles. Must have voltage. Could it be a bad ground from the pump thats lose? How frequently do fuel pump go out? What are the symptons?
post #6 of 9 Old 04-25-2009, 11:39 PM
The relay is the switch that triggers the fuel pump.
If the relay isn't working the pump won't either.
I would look at the killswitch.
As long as the killswitch gets a good connection then the relay and pump will run fine - until you flick the switch again and don't get a connection.
You can try bypassing the killswitch to rule it out.
post #7 of 9 Old 04-25-2009, 11:41 PM Thread Starter
thank you, Ill try it and see what i find. Helpful as always!
post #8 of 9 Old 04-26-2009, 1:11 AM Thread Starter
Simple. Floppy ground coming from the pump - fixed!
post #9 of 9 Old 04-26-2009, 1:13 AM
Excellent :-)
f4i headlight/fuel issue vietladin Honda CBR 600 7 01-29-2008 8:05 PM
2000 F4 Fuel Issue. HELP! modigity Honda CBR 600 11 03-15-2007 10:33 AM
Fuel leak issue, help please! robbied Honda FireBlade 5 02-05-2007 7:13 AM
Fuel pump issue? klayman Honda FireBlade 5 09-27-2006 9:03 PM
ARGH!#@#! Fuel Pump Issue victoRR Honda FireBlade 15 10-09-2004 3:57 PM
