929 brake lines - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 04-25-2009, 11:38 PM Thread Starter
929 brake lines
okay well i was digging through some drawers in my garage and i found some brake lines ive accumulated over the past couple years from friends. i do have a couple of issues though.
1. no banjo bolts
can i use the factory 01 929 banjo bolts and washers? if not what size do i need?
2. i only have 2 matching lines i can use up front.
can i eliminate the "Y" fitting and run the two lines directly upto the master cylinder?
Ramathorn is offline
post #2 of 8 Old 04-25-2009, 11:46 PM
Re: 929 brake lines
1. no banjo bolts
I really don't understand what it is you're asking.
Personally, I wouldn't bother with old lines - new braided lines are cheap.
I don't know what you mean by using the 929 bolts. What are you using them for exactly? Don't re-use the washers though - get new ones.
Yes, you can run the lines directly to the master cylinder if you prefer. Racebikes are required to do it this way. You'll need a double banjo bolt of course.
post #3 of 8 Old 04-28-2009, 12:09 AM Thread Starter
Re: 929 brake lines
yeah i already have these lines though so these are even cheaper (the rear is brand new actually).
i seem to be running into an issue of finding the double banjo bolt in town from reading i think ive come up with the correct size (10x1.25). can anyone confirm this?
post #4 of 8 Old 04-28-2009, 12:13 AM
Re: 929 brake lines
When I replaced the bolts on my '98 GSXR with aluminium ones I discovered the calipers and master cylinder were different pitches so I aways check first.
Measure the pitch of the bolts already in there.
post #5 of 8 Old 04-28-2009, 8:46 AM
Administrator
Red Rider's Avatar
Reputation Power: 47
Re: 929 brake lines
Search: 'banjo bolt' - Motorcycle Parts and Gear Online - MotoSport
Red Rider is offline
post #6 of 8 Old 04-28-2009, 11:19 PM Thread Starter
Re: 929 brake lines
i actually ordered my double banjo with bleed valve from kneedraggers.com along with a couple other little things
post #7 of 8 Old 04-28-2009, 11:47 PM
Re: 929 brake lines
And for future reference, what pitch did you end up ordering?
post #8 of 8 Old 04-29-2009, 11:34 AM Thread Starter
Re: 929 brake lines
10x1.25
brake lines need4speedrr Introductions 2 11-21-2008 12:25 AM
RC-51 brake lines on a 954? jamilrahman Honda FireBlade 1 03-28-2006 10:51 AM
Brembo BRAKE MC & Galfer Superbike BRAKE Lines southpark460 Honda RC51 0 01-08-2006 2:28 AM
Brake Lines showmethebombs Honda RC51 25 08-12-2004 8:35 AM
SS Brake Lines Heavy-Dee Honda FireBlade 4 08-04-2003 3:34 PM
