Track Gearing Change - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 04-26-2009, 1:46 AM Thread Starter
Just came off my second 2 day track day stint at Buttonwillow Raceway in central Cal. I've decided I want to change up the gearing for this track so as to have a taller first gear. I believe the stock sprocket set up is 16/42. I've thought of running a 15 front and a 42 rear, perhaps changing to a 520 chain. Does anyone know if there are any problems going to a smaller drive sprocket up front. Does it make more sense to go down a few teeth at the rear instead? I havent really considered going with a taller first gear on the tranny. I'd probably just prefer swapping out sprockets based on where I'm riding. Any recommendations on brands? I'm considering Driven sprockets and a DID or RK chain, probably one of the higher end versions on the latter. Do the aluminum sprockets hold up?
rbiker is offline
post #2 of 4 Old 04-26-2009, 1:58 AM
Re: Track Gearing Change
For a taller first gear you need to raise the gearing by increasing the front or decreasing the rear sprocket teeth.
It depends on what the highest speed is around the circuit but I recommend gearing _down_ to avoid using first gear if possible.
Aluminium sprockets of good quality and a 520 race chain are fine.
post #3 of 4 Old 04-26-2009, 2:29 AM Thread Starter
Thanks BladeRacer. Not sure why I brain farted on the up/down, but your suggestion of gearing down makes a lot of sense now that i think about it. The track I'm referring to doesnt have a super long straight in the two configurations we've run, so limiting top speed does not come into play.
So then, gearing down would again mean decreasing the front or increasing the rear. If anyone has run a smaller front sprocket, let me know.
rbiker is offline
post #4 of 4 Old 04-26-2009, 2:31 AM
There is no problem in going down one tooth on the front. Two may be possible but may cause faster wear of the swingarm buffer rubber.
The gap between first and second is the widest in the box and has neutral between them so it's generally best to try to avoid the lower gears where possible.
Can I change the gearing in my shaft drive Honda? Amanaland Honda Tourers 0 09-04-2008 6:32 PM
Can I change gearing on my '83 VT750C? Amanaland Honda Cruisers 2 09-04-2008 6:19 PM
Gearing change-Please HELP!! coker98 General Discussion 3 07-01-2008 11:10 AM
re-gearing a '00 F4 monkey Honda CBR 600 4 06-14-2007 9:21 PM
Durability of chain with gearing change TheJackal Honda FireBlade 3 05-05-2007 12:05 PM
