Acceleration Loss Mid-Flight - Honda Motorcycles - FireBlades.org
post #1 of 36 Old 04-26-2009, 12:10 PM Thread Starter
Reputation Power: 11
Send a message via MSN to Knewz
This morning while on my way to work on the freeway, i kinda lost hp to my bike, i think. I was doing about 85 at the time and was about to pass a car and click it into 5th when suddenly my bike slowed, engine got quiter, and throttle became less sensitive, and it kinda was jumpy. Usually i experience these symptons when im about to run outta gas and need to switch to reserve. But seeing as how i filled up before i got on the road this wasn't the case. I thought the bike was over heating but the temp gauge was dead center (and working). But it never shut off, i jus lost acceleration power. The engine got quite, my pipe gave a more deeper rumble, and the throttle was loose. I slowed down to about 65 and tried to accelerate back up and it took me a while to get to 75, and i had to almost twist the throttle all the way. this isn't normal for me cause my throttle is really sensitive; i barely have have to move my fingers normally to get going. Well i keep moving and about 5 miles down, the bike jumped back to "normal". Acceleration picked up, pipe voice was normal, throttle was senstive again... then .... about 30 secs later it slowed again, back to the low engine noise and deep pipe sound. When i arrived at my destination, i noticed the engine was kind of sputtering. I felt the gas coming from the pipe and it was choppy. No idea what the problem could have been, never seen this before.I've been having minor issues at start up with the choke and air-mixture, but never and in-flight issue. Worried and broke. Please advise
Knewz is offline
post #2 of 36 Old 04-26-2009, 10:11 PM
Reputation Power: 21
Re: Acceleration Loss Mid-Flight
sounds like maybe fuel pump going out or pressure regulator.....
GENERAL ROBERT E. LEE
Jetpilot07 is offline
post #3 of 36 Old 04-26-2009, 11:14 PM
Have you modified the electrical system in any way? All stock ignition, plugs, coils, plug wires, etc? How many miles do you have on that stuff?
brads955 is offline
post #4 of 36 Old 04-27-2009, 10:01 AM Thread Starter
everything is stock... no mods. its got about 24k on it. Funny thing is, when i started it up it was still acting funny. I got about 5 miles down the road then it jumps back to normal. Since then i've probably been about 10 more miles on it with no problems.
Knewz is offline
post #5 of 36 Old 04-27-2009, 11:52 AM
You say it felt like it was overheating - have you checked the coolant?
Check the fuel pressure regulator as well. Can you smell petrol in the crankcase?
post #6 of 36 Old 04-28-2009, 1:09 PM Thread Starter
i did smell something. It wasn't a strong petrol smell but kinda faint sweet/burning oil mix scent.
Knewz is offline
post #7 of 36 Old 04-28-2009, 1:18 PM
I can't smell so I can't clarify that for you but I believe burning coolant has a sweet smell.
Is the radiator full of coolant?
post #8 of 36 Old 04-28-2009, 1:21 PM Thread Starter
full? doubt it. probably should look into fixing that.
Knewz is offline
post #9 of 36 Old 04-28-2009, 2:57 PM
Why do you doubt it? Surely if you have reason to doubt the radiator is full you'd top it up before riding it next?
If the level is lower than the temperature sender in the thermostat housing the gauge will read fine despite the engine overheating.
Let us know how much coolant is missing when you check it.
post #10 of 36 Old 04-28-2009, 5:04 PM Thread Starter
so i checked the coolant reservoir ... and .....unless i'm blind, it is completely empty. Just to be sure i checked the right thing, it's on the right side of the bike and has a cap labeled "coolant" right? Which leads to a off-white reservoir behind/under the gas tank ( or in that general area)
Knewz is offline
post #11 of 36 Old 04-28-2009, 11:37 PM
I'm not really concerned about the reservoir.
Is there coolant in the engine and radiator?
post #12 of 36 Old 04-29-2009, 1:22 AM Thread Starter
didn't see any in there.
Knewz is offline
post #13 of 36 Old 04-29-2009, 1:35 AM
Then I guess it overheated :-)
Maybe you should try filling the system up with coolant and see if it runs okay?
Since it appears to have sucked the reservoir dry as well it must've been very hot indeed.
Does it still run?
post #14 of 36 Old 04-29-2009, 2:58 AM Thread Starter
yeah it runs. but if it idles for more than 2 minutes the temp. gauge goes straight H. If i can get on the highway, it naturally cools and will remain between C and H respectively. I looked into some coolants: prestone, supertech, and another brand i can't remember who makes SuperCool. prestone was silicate free, not sure about the others but all could be used in all Al engines. I'm guessing since there's no coolant in there now there's none to change, so i can just add.
Knewz is offline
post #15 of 36 Old 04-29-2009, 3:01 AM
When you fill it up keep an eye out for white smoke and watch the coolant level in the radiator. If you start losing coolant you may have done damage to the engine.
Flight of the Conchords OSIRIS Off-Topic 0 10-19-2005 12:10 AM
squeeking from 954 on acceleration? Red99TA Honda FireBlade 11 09-01-2005 8:33 AM
Flight of the Bumble Bee Kuss929 Off-Topic 5 06-09-2005 4:25 PM
Optimal Acceleration Creeper General Discussion 4 04-03-2005 1:45 PM
Space flight oldfogey Off-Topic 2 10-05-2004 11:55 AM
