Frame polishing - Honda Motorcycles - FireBlades.org
post #1 of 3 Old 04-28-2009, 3:45 AM Thread Starter
Send a message via AIM to MTXMUGEN
Frame polishing
I have a 96 900rr. After some thought i decided to polish the frame. I noticed that there is a finish of some sort protecting the aluminum alredy. I was thinking about using some aircraft remover to get rid of that. then sand and polish.
is there any easier way to do this? Should i seal the bare aluminum after?
MTXMUGEN is offline
post #2 of 3 Old 04-28-2009, 9:13 AM
Reputation Power: 22
Re: Frame polishing
use easy-off oven cleaner to remove the paint, unlike normal paint which is easily removed with aircraft stripper, the powder coat on motorcycles is electricaly charged and then baked on, so the best thing to use is easy-off. then once you are ready, sand with 1000 grit, then again with 1500, and then 2000, anything lower than 1000 and you risk deep gouges which is hard to fix, and a good aluminum polish will protect it just fine.......but remember, once you do this, it's a pain to keep clean.
GENERAL ROBERT E. LEE
Jetpilot07 is offline
post #3 of 3 Old 04-28-2009, 1:35 PM
Reputation Power: 12
Re: Frame polishing
Yea but it looks awesome i clean mine about every month, might be more than necassery, everything on mine is polished, wheels, frame, swingarm, but it looks really good makes it stick out from the rest of the bikes
95erion is offline
929 polishing frame. ?'s willch0 General Discussion 0 02-11-2007 6:28 PM
cleaning and polishing coffeeman690 General Discussion 3 01-21-2007 5:57 PM
frame polishing detourbeach Honda FireBlade 11 06-02-2006 9:49 PM
question about polishing? TheShowOff Honda FireBlade 28 02-12-2005 1:07 PM
Polishing Alterative chrisbratton22 Honda FireBlade 1 02-08-2004 11:03 AM
