two potential issues. - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 04-28-2009, 5:02 PM Thread Starter
So earlier this spring I overheated my bike....up near 260+ Thank god I didnt warp the head or blow a gasket. My fan wasnt coming on at the right temp (220ish) I said screw it and wired my own switch so now I can turn my fan on when I want....like around 190 degrees and rolling into a set of lights. Today on my ride it was 85 degrees out and even with my fan on at a long light the temp would climb to 218-220.........normal? It climb slowlely, Id say a degree every 5 seconds, but still......once we took off again up over 35 MPH it would cool down. am I just paranoid?
The second thing is my bike seems to vibrate a lot up over 8000RPM. It still pulls and there are no unusual noises but seems.... not quite normal. There is nothing as far as noises or anything else to suspect a problem but vibration. Normal? Normally when I have it that high in the revs it only for a second or two right before I shift but if I keep it there for a few second it vibrates my legs.
Before everyone tells me that wiring in my own switch I will say that its nice to be able to control when the fan comes on but sooner or later Ill just replace the temp sender and leave the fan to the Honda engineers
So whats up? Am I just paranoid with both these things?
temperedtim929 is offline
post #2 of 6 Old 04-28-2009, 5:48 PM
Administrator
Red Rider's Avatar
Reputation Power: 47
Re: two potential issues.
Paranoid...
Red Rider is offline
post #3 of 6 Old 04-28-2009, 5:55 PM
Reputation Power: 59
Originally Posted by Red Rider View Post
Paranoid...
If the temperature of the bike has not reached the temperature needed for the thermostat to open, then the fan would therefore be useless as there would be no water passing through the radiator.
When the temperature comes up next time (to the temp the fan used to kick in i.e. 220), switch the fan on and record in your mind whether the temperature goes down a few degrees.
Twincam is offline
post #4 of 6 Old 04-28-2009, 6:02 PM Thread Starter
good to hear. Im so paranoid. I obsess about everything!
post #5 of 6 Old 04-28-2009, 6:40 PM
y2blade is offline
post #6 of 6 Old 04-29-2009, 12:07 AM
First time I've ever used one of those smiley things :-)
Potential Problem.... FB1000inPA Off-Topic 0 11-12-2008 11:29 AM
potential new owner... a few questions! jream Honda FireBlade 1 06-19-2008 1:56 PM
Potential newbie! tufty Honda RC51 2 10-25-2007 4:08 PM
RC51 Potential... MarinoKouch Honda RC51 13 06-07-2007 9:21 PM
potential 954 convert muab Honda FireBlade 32 10-25-2004 6:02 PM
