do I need a power comander - Honda Motorcycles - FireBlades.org
post #1 of 31 Old 04-29-2009, 3:07 PM Thread Starter
I have changed the stock exhaust with the 2 brothers, it is running fine and not missing or cutting buth when I pull the trottle hard from around 5rpm I notice that it refs up to 10 to quickly, I never felt all this power before on my bike, do you think that the bike is in need of a power comander or this is normal?
all I know is that this two brothers changed the sound and performance especially at the low end
ton304 is offline
post #2 of 31 Old 04-29-2009, 3:22 PM
Reputation Power: 39
Re: do I need a power comander
I have a two bros s/o on my bike with a power commander and I love it. Smooths out the power and makes the mid range a little more usable.
WyoJames is offline
post #3 of 31 Old 04-29-2009, 3:24 PM Thread Starter
did you notice a lot more power on mid range before installing the power comander?
ton304 is offline
post #4 of 31 Old 04-29-2009, 9:58 PM
i don't know, i put a power commander on before I got my exhaust. I feel that the power commander is more important than a slipon
WyoJames is offline
post #5 of 31 Old 04-29-2009, 11:24 PM
Reputation Power: 11
sounds good. I have a 2 bros slip on coming next week. nice to hear you can feel the differance. which can do you have. m2? m5? somthing else?
matt.k is offline
post #6 of 31 Old 04-30-2009, 12:12 AM
I'm no expert in the least bit, but I also got the Power Commander before I got my exhaust. But I quickly replaced my stock mufflers with Yoshi slip-ons and KNEW that I needed to remap the bike bacause of the change in flow. I heard this early on, and knew that when you change the exhaust and the flow you're going to affect the fuel mixture and any bike is naturally going to run richer or leaner. Sure, you're going to notice a difference with the new muffs, but my suggestion is to get a Power Commander. That way, you can tweak it to your exact mods. And ironically, there is a map designed specifically for bikes with Two Brothers slip-ons! My bike ran so much better after I changed the map once I got my new mufflers and removed the cat, plus added a K&N air filter.
So anyway, I would say, from experience, that yes it would be a great idea to install a Power Commander. Everyone I spoke to or who I listened to in forums said it was an absolute MUST HAVE!
Good luck, and let me know what you decide and how it all turns out!
919dude is offline
post #7 of 31 Old 05-01-2009, 1:44 PM Thread Starter
f... I had to thow the bike, it stopped moving. seems that the clutch is gone. I had this changed this due to clutch recall
ton304 is offline
post #8 of 31 Old 05-01-2009, 1:56 PM
I guess that explains why it was revving so easily?
Have you done a recent oil change?
post #9 of 31 Old 05-01-2009, 2:11 PM Thread Starter
yes I also changed the oil, i think the new clutch was badly mounted
ton304 is offline
post #10 of 31 Old 05-01-2009, 2:13 PM
How much mileage have you done on that oil?
Is it the same as the oil that was in it before?
post #11 of 31 Old 05-01-2009, 2:18 PM Thread Starter
same brand but this time syntetic, silcolene pro 4
ton304 is offline
post #12 of 31 Old 05-01-2009, 2:22 PM
Change it back to the stuff you ran before.
I had exactly the same thing when I switched to full-synth on my GSXR.
post #13 of 31 Old 05-01-2009, 2:23 PM Thread Starter
thanks for your advice mate, clutch is ****ed now anyway
ton304 is offline
post #14 of 31 Old 05-01-2009, 2:27 PM
Not true.
My bike did exactly what yours is doing.
I drained the synth out, emptied the filter and put the semi-synth in that I'd always run and it was like new immediately. It never, ever played up again and I still have it.
If the full-synth is fresh just give it to somebody else that runs it successfully.
post #15 of 31 Old 05-01-2009, 3:58 PM
Reputation Power: 17
Thats funny cause when I read your first post, the way you explained it sounded like a clutch going out.
Rip the clutch cover off and replace or scrub the disc with some sand paper man!
BigBassTurd is offline
Wanted power comander for 954 usb jmoney2001 Wanted 2 12-20-2008 12:17 AM
WANTED!! power comander blade300 Wanted 2 09-26-2008 6:11 AM
Power Comander JuniorJ2 Honda FireBlade 2 06-19-2007 11:31 AM
929 power comander maps cbr929bikerboy Honda FireBlade 6 06-22-2006 7:03 AM
Power Comander Matt227 Honda RC51 3 05-04-2006 1:15 PM
