Brake light stays on - Honda Motorcycles - FireBlades.org
post #1 of 13 Old 04-29-2009, 11:36 PM Thread Starter
bjay51d's Avatar
i washed my bike and now the brake light stays on.I tried adjusting the rear brake spring switch and still nothing.I noticed when I was doing that water was coming from the inside of the tube where the two wires are.Is this common?
bjay51d is offline
post #2 of 13 Old 04-30-2009, 10:39 AM
Reputation Power: 22
Re: Brake light stays on
you may have washed trash up inside the tube which would get lodged in there and lock it in place, have to remove and try to tap it out.
GENERAL ROBERT E. LEE
Jetpilot07 is offline
post #3 of 13 Old 04-30-2009, 8:22 PM
Reputation Power: 12
I had that happen to me but it was because I had adjustable front levers and the spring was going out, as a result the brake light stayed on...
Evil R is offline
post #4 of 13 Old 05-01-2009, 9:47 PM Thread Starter
bjay51d's Avatar
I just disconnected the rear switch and its still lit..,I also took off the wires from the front switch.So with both switches unhooked and My light is still on...I'm starting to get worried
bjay51d is offline
post #5 of 13 Old 05-02-2009, 12:43 AM
It's magic :-)
I assume you are certain that it was working correctly before you washed it?
Do you mean you removed the switches and didn't re-connect the wires together and the light stays on?
I don't know if the switches are open or closed but if they're open switches (even just one of them) the light would come on when disconnected and off when reconnected.
post #6 of 13 Old 05-02-2009, 3:51 PM Thread Starter
bjay51d's Avatar
It's magic :-)
I called a buddy that I was riding with earlier and he was certain it was working.I came home after the ride and washed off all the bike and went back out later that night,thats when I noticed it wasnt working....I disconnected the rear switch plug and took the wires off of the front switch and its still lit.I did order both front and rear switches but I;m starting to think it my intergrated tail light
bjay51d is offline
post #7 of 13 Old 05-02-2009, 3:53 PM
Does the light go off if you connect the switch wires together?
post #8 of 13 Old 05-02-2009, 6:56 PM
check your existing switches with a multimeter.
I have just checked the manual and the switches are NO (normally open) contacts and the lever changes the state to closed, therefor...there should be continuity when the lever is pulled in or the rear pedal pressed.
if you release the lever or pedal, there should be no continuity through the switch.
i would also say its something to do with your integrated tail light as if you have disconnected all the switches the light should be off
firebladeking is offline
post #9 of 13 Old 05-02-2009, 8:19 PM Thread Starter
bjay51d's Avatar
no sir
bjay51d is offline
post #10 of 13 Old 05-02-2009, 8:39 PM Thread Starter
bjay51d's Avatar
Well,well,well I found out what the problem is ''clear alternatives makes a bullshit product''.I plugged in the stock light and it shuts off as it should but now have no blinkers.
bjay51d is offline
post #11 of 13 Old 05-03-2009, 1:11 AM
no sir
I hate being called sir!
It's a rare word here but it usually means you've been very naughty or somebody wants you to buy something :-)
Glad you got it worked out.
post #12 of 13 Old 05-03-2009, 12:52 PM Thread Starter
bjay51d's Avatar
thanks for your help...Im gonna call clear altternatives and find out what could be done.
bjay51d is offline
post #13 of 13 Old 05-16-2009, 12:01 AM Thread Starter
bjay51d's Avatar
Clear alternatives really stands behind their products its almost a no questions asked deal.I very impressed with the customer service and the fast turn around.
bjay51d is offline
1985 honda nighthawk 700sc neutral light stays on crockett General Discussion 4 01-03-2009 9:05 AM
Front brake lever won't turn on brake light kevinb6825 Honda FireBlade 3 04-13-2008 9:40 AM
Brake light stays on? EvLTwiN Honda RC51 9 05-28-2007 5:59 PM
CEL Light Help! When it come on it stays on no flashing int76 Honda FireBlade 4 11-19-2005 6:11 PM
Neutral light stays on DS760 Honda FireBlade 0 07-14-2005 3:03 AM
