Need help addressing some 954rr issues... - Honda Motorcycles - FireBlades.org
post #1 of 9 Old 05-14-2009, 1:50 AM Thread Starter
Hey guys I'm new to this forum! I been doing some searches trying to figure out a solution to my problem. Anyways on a 2003 954RR 8,500 miles. Micron slip on, K&N. I just had it serviced, and they said the valves were within spec. Always used Honda HP4S oil in her.
- Slight knocking/chattering noise at idle or low rpm's
- Cold start in the morning, fires up and then will stall. Start it again, it will races to 2,000 rpm and warms up fine.
- Been noticing it's not as smooth off idle anymore as it used too, power comes on strong around 3000.
- Idles between 1,000-1,500 when warm.
- Strong exhaust smell, tip of the pipe is sooty.
My conclusions:
- Faulty FPR
- Faulty Cold Start Solenoid
Anyone have similar problems? I'm going to take the tank off soon, and I have a new set of plugs. Trying to get all my ducks in line before I do that. Thanks in advance!
forcedinduction is offline
post #2 of 9 Old 05-14-2009, 2:13 AM
Re: Need help addressing some 954rr issues...
My conclusions:
- Faulty FPR
I would tend to agree the FPR is the obvious culprit.
The fast idle isn't a solenoid. It's a simple wax element immersed in the coolant that expands with temperature.
I'd recommend binning the K&N and run an OEM filter.
How low are the revs with the chattering/knocking you mentioned?
post #3 of 9 Old 05-14-2009, 3:43 AM Thread Starter
So a OEM filter is better than K&N? I'll add that to my list.
The knocking/chattering is from about idle to 3k or so. It light, and I've had an XR650R that sounded similar, it was the chain tensioner. You can hear it clearly with your head over the forks looking down, it may be an exhaust leak too. I'll have to take a peek. Thanks for the quick reply!
post #4 of 9 Old 05-14-2009, 3:55 AM
just changed my fpr for the same reasons on my 929 but bladeracer is right you should bin the k&n and go back to stock. as for noise my 929 knocks and rattles until 3-4k rpm and then rips after that, i've checked just about everything looking for the noise but to no avail, there are several posts regaurding knocking noises which lead me to beleive that 929/954s are just noisey....
dick hurtz is offline
post #5 of 9 Old 05-14-2009, 3:58 AM Thread Starter
Great info guys, just ordered my FPR and air filter from ronayers, I'll post an update when I get it all in! Thanks!
post #6 of 9 Old 05-15-2009, 5:52 AM
what is a FPR?
strumfuadi is offline
post #7 of 9 Old 05-15-2009, 6:01 AM
Reputation Power: 12
fuel pressure regulator
The only thing I trust on the road are the nine hundred and fifty four CC under me..........
flipsidenv is offline
post #8 of 9 Old 05-15-2009, 6:53 AM
aha!
does anyone know what should be the normal pressure?
post #9 of 9 Old 05-15-2009, 6:57 AM
Originally Posted by strumfuadi View Post
aha!
50psi at idle.
It's not the pressure that's the problem though.
It's operated by vacuum from the engine.
If the vacuum diaphram tears then fuel is sucked straight into the engine.
98 CBR F3 issues rich98f3 Honda CBR 600 5 12-26-2008 4:07 PM
Help! serious issues BigO General Discussion 4 05-10-2007 12:51 PM
954 known issues? maxredline Honda FireBlade 29 09-11-2006 1:18 PM
Think I have MAJOR ISSUES 954rr Oil/Exhaust E-vadr Honda FireBlade 21 03-13-2006 10:41 PM
Known CCT Issues? Oldschoolcbr Honda FireBlade 9 06-25-2003 11:35 PM
