2001 929_ Gas light wont turn off - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 05-19-2009, 3:50 PM Thread Starter
Just purchased 2001 929rr_ when purchased there was little gas in the tank so I expected the light to be on. However now with a full tank the light will not turn off.. Is there a connection that I could check and/or where is the actual censor for the fuel light (assume in the tank) can it be tested....
elafing is offline
post #2 of 4 Old 05-19-2009, 9:21 PM
Reputation Power: 11
Re: 2001 929_ Gas light wont turn off
Yeah, the sensor is in the tank with the pump, it all comes out on a plate that bolts to the underside of the tank. I'd check the connector first too, which is self evident when you lift the tank. If you do take the pump out, it is probably easier to drain as much fuel as you can from the tank, then remove the tank from the bike, turn it upside down and remove the plate with the pump on.
Good luck.
shittyarsedmonk is offline
post #3 of 4 Old 05-27-2009, 3:01 PM Thread Starter
Just to clearify. I see quite a few views of this thread. When I purchased the bike it was at night time and with work I had only been riding in the evening. However on memorial day I went riding during the day and to my suprise there was no light on. It seems there is an aftermarket bezel on the face and its not seated properly so the light shines in past the bulb for the low fuel and made it seem alluminated.. But I would like to thank shittyarsedmonk for chimn in on the pump issue.... "I said good day"
elafing is offline
post #4 of 4 Old 05-27-2009, 4:58 PM
No worries dude, happy riding
2001 929 - No working headlights/turn signals/cluster light? Tried almost everything wjbarton Honda FireBlade 20 06-28-2019 6:15 PM
I need HELP!! My oil light wont turn off.. 02GSXRider General Discussion 20 09-30-2011 5:31 PM
Front Brake lever wont turn stop light on... adespotos Honda FireBlade 11 03-15-2009 12:05 AM
2001 cbr 929 wont turn over when starting black empire Honda FireBlade 11 09-11-2008 1:11 AM
fan wont turn on dg_806 Suzuki Motorcycles 1 06-08-2008 4:36 PM
