929 No low beam - Honda Motorcycles - FireBlades.org
post #1 of 16 Old 05-24-2009, 12:55 PM Thread Starter
929 No low beam
I am new to this forum i hope i am posting in the right place. Any how i have 2000 cbr 929 with no low beam. The bike runs fine every other light works, replaced relay replaced fuse checked start switch checked hi/low beam switch and checked bulb. I get twelve volts to the low beam connector with no bulb installed when i put in the bulb i get no voltage. Where else can i look for a fault? Any help would be appreciated.
longhornfan is offline
post #2 of 16 Old 05-24-2009, 3:18 PM
Re: 929 No low beam
Is the light blown?
post #3 of 16 Old 05-24-2009, 3:36 PM Thread Starter
Re: 929 No low beam
no i plugged in the high beam side and it works just fine
post #4 of 16 Old 05-24-2009, 4:56 PM
Reputation Power: 11
Send a message via Yahoo to curbaez
Re: 929 No low beam
u think u got a shortcut at the socket ? take voltage from the wire, maybe you may have to do a soldering job at the socket.
curbaez is offline
post #5 of 16 Old 05-24-2009, 5:50 PM Thread Starter
Re: 929 No low beam
i will give a try let you know how it works out
post #6 of 16 Old 05-24-2009, 9:29 PM Thread Starter
Re: 929 No low beam
checked the wiring before the connector everything is good.
post #7 of 16 Old 05-24-2009, 9:31 PM
Re: 929 No low beam
Do you mean you've fixed it?
post #8 of 16 Old 05-24-2009, 11:20 PM
Re: 929 No low beam
The person that I bought mine from put high wattage bulbs in it and fried the insulators. Had to replace all three in the long run.
truff1 is offline
post #9 of 16 Old 05-25-2009, 10:55 AM
Re: 929 No low beam
do a search in the forums for your problem. you may find the answer. A lot of people ( myself included ) had the same issue.
MACI4LIFE is offline
post #10 of 16 Old 05-25-2009, 3:16 PM
Re: 929 No low beam
so you have 12v to plug so that side is good did you cheek the ground side at the plug just a thought
fine929 is offline
post #11 of 16 Old 05-25-2009, 4:14 PM
Re: 929 No low beam
Ya probly bad ground. plug the bulb in, with it on you should have close to 0 volts on the ground side of the plug, with a good bulb that is.
fido is offline
post #12 of 16 Old 05-29-2009, 1:07 AM Thread Starter
Re: 929 No low beam
taking it to the shop
post #13 of 16 Old 05-29-2009, 1:41 AM
Quoted: 6 Post(s)
Reputation Power: 26
Re: 929 No low beam
If it's at the shop, it's too late. If not, then I suggest you replace the accessible wiring. A high wattage bulb can not only burn the insulators (I assume by this you are talking about the colour-coded wire covering) but the wiring itself. There is enough continuity to hold some voltage when you put the voltmeter to it, but the moment you get any sort of current flow, like when you try to operate the bulb, the connection(s) go bad.
I used to struggle with that sort of thing on my rusty old British cars when I first started driving. The damned Lucas wiring was NFG when exposed to salty Canadian roads. Hmm, that reminds me of my first car, a 1962 Austin A40 Mk I Countryman. What a POS.
Anyways .... if I am correct, and you have some 99.5% fried wiring, it might prove very expensive to have that diagnosed and repaired at a shop. If I were in your shoes I would replace as much of the wiring as I could get to before handing it over to somebody who would charge me.
ghbzorro is offline
post #14 of 16 Old 05-29-2009, 3:21 PM
Re: 929 No low beam
fark. no one listens.
https://www.fireblades.org/forums/hon...-ever-see.html
try that first and tell us what happens.
post #15 of 16 Old 05-29-2009, 3:57 PM
Quoted: 6 Post(s)
Re: 929 No low beam
Agreed that it's best to search for threads before starting a new one. Hopefully the start switch is the cause of the problems, and not burned up wires. But I thought that thread and the linked one talked about ALL headlights not working, not just low beam no working?
ghbzorro is offline
need low beam wiring diagram pickleboo Honda FireBlade 11 04-30-2009 4:50 AM
High Beam Indicator silverback Honda FireBlade 0 07-18-2008 11:30 PM
RC-51 Dual Low Beam Headlights Snowayman Honda RC51 14 10-19-2007 3:36 PM
Low Beam? TheTruth21 Honda FireBlade 5 03-30-2005 10:56 AM
High beam adjustment Joel Honda FireBlade 9 08-04-2003 8:44 PM
