need help asap - Honda Motorcycles - FireBlades.org
post #1 of 33 Old 05-25-2009, 9:15 AM Thread Starter
need help asap
i need help my 954 has a problem...heres how it started i was riding and my bike had a little trouble starting then it was cutting off when i reved it.so i rode it on the street and if i punched it anything above 6000 rpm it nose dived and turned the bike off ....so i got home saw a silver piece of metal sensor was just hanging.SO I bolted IT TO THE CHASIS and now the bike stayes running but hesitates low rpm,also the temp gauge is going nuts.when i rev it the temp reads 200 when i rev it it goes to 170 then jumps back to normal every time i throttle on it the temp lowers and the bikes not warming up...any ideas????????
nkrosser is offline
post #2 of 33 Old 05-25-2009, 10:05 AM
Reputation Power: 11
Re: need help asap
It sounds like electrical if your gauges are going mad. Are you sure that 'silver piece of metal' isn't an earth cable? Where on the bike is it?
shittyarsedmonk is offline
post #3 of 33 Old 05-25-2009, 10:17 AM Thread Starter
Re: need help asap
if your sittin on the bike its in the tail section right under the seat to the right of the battery directly outside of the undertail and trunk area silver with 2 wires coming to it
nkrosser is offline
post #4 of 33 Old 05-25-2009, 10:22 AM Thread Starter
Re: need help asap
from the charts ive seen it calls it a resistor??
nkrosser is offline
post #5 of 33 Old 05-25-2009, 10:24 AM
Re: need help asap
What colour are the wires? Is it just a metal 'tab' with a hole for a bolt? Does it come from the battery, or the loom?
post #6 of 33 Old 05-25-2009, 10:26 AM Thread Starter
Re: need help asap
dont know the wire colors not home now yes its a tab with single bolt hole comes from the wirring harness
nkrosser is offline
post #7 of 33 Old 05-25-2009, 10:27 AM Thread Starter
Re: need help asap
2003 Honda Motorcycle Parts for CBR954RR, Electrical - WIRE HARNESS (2) look at this its number 12
nkrosser is offline
post #8 of 33 Old 05-25-2009, 10:31 AM Thread Starter
Re: need help asap
also how do i check and see if my bikes throwing any codes????
nkrosser is offline
post #9 of 33 Old 05-25-2009, 10:42 AM
Re: need help asap
Yeah it sounds like an earth wire, of which there are a few. A bad connection, or none at all in your case can throw up some wierd symptoms. Make sure it's clean and the frame where it bolts. If there's bits hanging off like that, it would be prudent to have the bodywork off and check other bolts. It depends on the condition and age of your bike, but checking connectors and earth points is a good idea every once in a while. I use silicone grease on electrical connectors to prevent or slow corrosion.
post #10 of 33 Old 05-25-2009, 10:46 AM Thread Starter
Re: need help asap
what do these earth wires do? and how do i check and see if im throwing codes
nkrosser is offline
post #11 of 33 Old 05-25-2009, 10:52 AM
Re: need help asap
Leave the bike on the sidestand, the ignition on and the run/off switch on run. If it's showing a fault the MIL will flash repeatedly.
post #12 of 33 Old 05-25-2009, 10:58 AM Thread Starter
Re: need help asap
k thanks
nkrosser is offline
post #13 of 33 Old 05-25-2009, 11:01 AM
Re: need help asap
The earth points are returns for the electrical circuits on the bike, or the negetives.
post #14 of 33 Old 05-25-2009, 11:22 AM
Re: need help asap
I think that's the resistor for the LED tail light.
post #15 of 33 Old 05-25-2009, 11:26 AM
Re: need help asap
When you say "turned the bike off" do you mean it turns off the ignition or is the engine stalling?
Is the radiator full of coolant (just to rule out an actual temperature problem)?
954 no start please need help asap! mullaney24 Honda FireBlade 1 05-18-2009 3:24 AM
need help ASAP with my new 929rr biggup21 Honda FireBlade 52 07-12-2008 1:56 PM
NEED ASAP- 929 or 954 CDI ECU pre5ton Wanted 3 03-09-2008 12:38 AM
Need help asap Langdon Honda CBR 600 9 03-02-2007 7:06 PM
Need Help Asap Ice Honda FireBlade 13 10-14-2004 10:54 AM
