Fuel injection problem - Honda Motorcycles - FireBlades.org
post #1 of 43 Old 05-25-2009, 5:37 PM Thread Starter
I was just out riding my 2000 929 and the fuel injection light came on. It blinks on the dash 3 long then 5 short. Has anyone ever had this code before.
that929 is offline
post #2 of 43 Old 05-25-2009, 6:26 PM
Reputation Power: 78
Re: Fuel injection problem
each long blink is actually ten blinks, so its code 35. This code is a faulty EGCV and motor air intake valve servo ie, the servo on the left side pulling the valves is having an issue. Either the gears are stripped or its electrical. Take the servo off, and simply run it with a 12V battery, if it works, check for continuity in the connectors/wires running to it from the ecm.
BurtonF166 is offline
post #3 of 43 Old 05-25-2009, 6:28 PM
when you run a circuit with a 12V battery and the servo, i forgot to add that RED is + and BLUE is - in the servo connector.
post #4 of 43 Old 05-25-2009, 6:33 PM Thread Starter
so if i take the cables off the servo motor do i have to readjust them when i replace or fix the servo motor
that929 is offline
post #5 of 43 Old 05-25-2009, 6:39 PM
if you want the servo to continue to pull the flapper in the airbox and the valves in the HTEV, then yes. First, check if the servo is broken, usually they arent cheap to replace. I just had this happen, i had code 34, basically same thing.
Its not very hard to re-attach the cables and get them lined up correctly so dont worry about it quite yet.
post #6 of 43 Old 05-25-2009, 6:48 PM
For accuracy, the EGCV is a very different system used on the 1000RR.
The 929/954 uses the HVIX system which includes the HTEV in the exhaust.
Otherwise, you're spot on :-)
post #7 of 43 Old 05-25-2009, 6:51 PM
Yes, adjusting the cables is part of normal maintenance anyway so I wouldn't worry about it.
Replacing the servo motor is not cheap - around US$200 from memory.
You could buy secondhand but I don't recommend it unless it's really cheap.
Whichever you do though _do not_ install a new motor until you have checked and cleaned the HTEV or it'll likely just burn out the new one as well.
post #8 of 43 Old 05-25-2009, 6:51 PM
haha thanks, first time pulling facts straight from the manual to help people out.
post #9 of 43 Old 05-25-2009, 6:52 PM
if it is broken, check ebay, I just got one last night for $30
post #10 of 43 Old 05-25-2009, 7:13 PM Thread Starter
i got to the motor is there an easy way to get some slack on the cables or do i have to go through the adjustment on the htev
that929 is offline
post #11 of 43 Old 05-25-2009, 7:17 PM
Just undo the adjusting nuts on the bottom of the cables.
You could try removing the lock screw on the pulley and remove it from the motor without adjusting the cables at all.
post #12 of 43 Old 05-25-2009, 7:17 PM
at the htev, there is a banana shaped bracket that is bolted to it, undo it, its a 10mm, then youll have plenty of slack.
post #13 of 43 Old 05-25-2009, 8:06 PM
So i have been having my fi/malfunction light coming on, but it doesnt blink, just stays on. bike runs fine, i recently put a new motor in it. also, where does the idle air motor belong? the bike was apart when i got it, and it runs fine, idles fine, but the air valve isn't on there. is this whats throwing the code? if so, where does it attach?
rr459rbc is offline
post #14 of 43 Old 05-25-2009, 8:10 PM
Air valve and air idle motors sound like 600/1000RR items.
The 929/954 doesn't use the system so you won't need the motor.
You need to pull the code to know what the error is.
Since you bought the bike in pieces you do have a manual?
post #15 of 43 Old 05-25-2009, 8:42 PM Thread Starter
well the motor works when hooked up to 12 volts, i havent checked continuity yet. Could it be that the htev is carbon ed up and not rotating.
that929 is offline
fuel injection system anthony Western USA 10 01-15-2009 5:03 PM
Fuel injection for 99 Blade Thunderflash General Discussion 6 06-16-2008 11:10 AM
CBR 9XX Fuel injection??? Smokngun Honda FireBlade 2 03-23-2008 8:01 AM
fuel injection daman23 General Discussion 2 12-27-2007 9:10 AM
Fuel Injection map for '03 954 FuTAnT Honda FireBlade 12 01-22-2004 9:34 AM
