2003 cbr 954rr engine miss - Honda Motorcycles - FireBlades.org
post #1 of 74 Old 05-29-2009, 9:00 PM Thread Starter
when shifting into 5th w.o.t. the bike started to miss so I pulled off the track I have spent thousands of dollars only to be told its got to be ignition on the dyno at 10,000 rpm the bike misses and fi light comes a/f is off just by a little bit not enough to cause a mis on and wont start I was wondering if anyone has had a similar problem on a 03 954 so far I have replaced plugs, intake manifold boots and clamps new pcIII usb to replace my old serial port one. removed alarm and remote start any help please I want to get back on the bike its been months of waiting!
ryanmoliver is offline
post #2 of 74 Old 05-29-2009, 9:47 PM
Re: 2003 cbr 954rr engine miss
At what revs does it miss when you're riding?
Is it at the same rpm in sixth gear as well?
Won't start?
Is the 10,000rpm miss only in fifth gear and is it on the bike's tach or the dyno's tach?
post #3 of 74 Old 05-29-2009, 9:54 PM Thread Starter
It misses at an idle in gear or in neutral after putting intake manifold boots and clamps on it idled fine then 80 percent pull on dyno was good made 126 h.p. base then 100 percent w.o.t. started missing at 10,500 rpm fi light came on and now it wont even start
post #4 of 74 Old 05-29-2009, 10:32 PM
Is it throwing an error code?
What does it do when it won't start?
What sort of mods have you done to the bike?
post #5 of 74 Old 05-29-2009, 10:42 PM Thread Starter
No codes just wont turn over like its electrical i had an alarm and remote start I removed everything aftermarket electrical and install another new pc111 usb thinking it may have been a problem flapper mod slip on 3 up in rear 520 and racetech springs sprung for my weight oh and an o2 eliminator the bike was running fine until I shifted at w.o.t I put a new barnett kevlar clutch with heavy duty springs in bought 8k ago
post #6 of 74 Old 05-29-2009, 10:48 PM Thread Starter
my thought is maybe a bad coil or a ignition pulse generator or a ecu or a short to ground in the ignition electrical system I was just wondering if anybody has delt with a similar situation it has been in the shop for almost 3 months now oil is fine no contamination or signs of fuel or coolant i dont think its mechanical cause the bike is not make any unusual noise its seems if its a spark issue no vaccuum leaks anymore they were fixed there was missing a clamp on the intake maifold boots I did trade some paint on the exhaust side of the bike eailer that day pulled off all seemed okay other than some paint was left on muffler from the other bike we bumped into each other nobody went down though
post #7 of 74 Old 05-29-2009, 11:17 PM
Won't turn over?
Do you mean the engine is seized or is the starter motor not engaging at all?
What do you mean by shifting WOT - you aren't just fanning the clutch?
The PAIR system was disconnected when you were measuring the air/fuel ratio?
The HTEV is working still?
post #8 of 74 Old 05-29-2009, 11:19 PM
Any chance the O2 sensor was hit?
post #9 of 74 Old 05-29-2009, 11:51 PM Thread Starter
good question but it has an o2 eliminator the o2 sensor is intact but is not being used due to power commander the engine is not siezed the shop just ran the valves and no signs of engine damage this appears to be electrical wot mean wide open throttle and for the a/f question idk the guys at the dyno shop just told me what i told you
post #10 of 74 Old 05-29-2009, 11:54 PM Thread Starter
and the bike misses at an idle in neautral so that rules out the clutch as for the no start problem this is a new prob after repair were started all the lights come on its as if a relay or something is the problem the reason we pulled out the remote start and the alarm
post #11 of 74 Old 05-30-2009, 12:00 AM
I know what WOT means but what do you mean by shifting at WOT?
The only way to shift WOT is to fan the clutch or kill the ignition.
Explain what happens when you try to start the bike.
Check that they disconnected the PAIR when they measured the air/fuel ratio.
post #12 of 74 Old 05-30-2009, 12:03 AM Thread Starter
under full acceleration at 12k rpm shifted no even a quick shift used the clutch only let up just a bit to shift w clutch never even hit the limiter
post #13 of 74 Old 05-30-2009, 12:03 AM
What does this mean?
post #14 of 74 Old 05-30-2009, 12:05 AM Thread Starter
light come on push start button and nothing this condition started after dyno runs the fi light never came on at the track only on the dyno after that they said it wont start they put in a new power commander to replace my old serial port one
post #15 of 74 Old 05-30-2009, 12:06 AM Thread Starter
it was a normal shift under a full load at high rpm I used the clutch only lifted on the throttle for an instance I was not doing a clutchless upshift
2003 954rr F/S ozthis For Sale 13 06-13-2007 3:16 PM
2003 954rr cams mo954rr Honda FireBlade 3 08-23-2006 8:47 AM
For Sale: Take a look at this 2003 954RR dbgoff For Sale 22 12-16-2005 5:17 PM
A well over due pic of my new 2003 954RR CBR4L General Discussion 6 08-16-2005 11:51 AM
2003 954 engine knock rogerjt General Discussion 1 11-26-2004 10:13 PM
