08 Blade...Coolant coming out of over flow? - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 05-30-2009, 11:21 AM Thread Starter
The bike was at 220 degress driving to work normal, shut it off and a small puddel of coolant came out of overflow after the bike was shut off. Now this happened a couple thousand miles ago but I called dealer and they say it happened becasue it was new and just had to much in it. It's been 2000 miles and it happened again, does anyone know if this is just normal or should I be alarmed and take it in. The bike is almost exp on warranty.
meyerz5 is offline
post #2 of 4 Old 05-30-2009, 2:10 PM
Reputation Power: 12
Re: 08 Blade...Coolant coming out of over flow?
I would take it in and have them check it out. At the least, they should flush the whole system for you and do a pressure test on it. Good luck.
partyhardryan16 is offline
post #3 of 4 Old 06-02-2009, 5:45 AM
Reputation Power: 15
Send a message via MSN to sb1000rr
bleeding it may help, might have an air lock in it...
sb1000rr is offline
post #4 of 4 Old 06-02-2009, 3:22 PM
Reputation Power: 11
take off the coolant tank cap, start the engine and watch the coolant in the tank to see if it bubbles. if it does, then u have a blown head gasket, if it doesnt............. , maybe its due to the summer temp. everything seems to run a little warmer.
rdj450 is offline
Coolant usage 2007 Blade jazzy Honda FireBlade 10 09-25-2008 10:48 AM
New Flow Bench SilverBullet Sponsor Deals / Group Buys 1 10-23-2007 10:15 PM
94 Blade intermittantly leaks coolant through overflow pipe! Bladerunner900 Honda FireBlade 4 04-04-2007 11:55 PM
Gas over flow question arkas Honda FireBlade 5 04-22-2006 12:33 PM
Changing Coolant / Flushing Coolant? cbr9two9guy Honda FireBlade 3 07-10-2005 9:13 AM
